.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Zoom to the selected points extents or window.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In a dwg file there some features and and select some of them and want to zoom to that selected features extents only.
or how can I get the extents for that collection so that I can zoom to it.
Please suggest
Re : Zoom to the selected points extents or window.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Assuming ids is the selected entities objectId array and ed the current Editor
Here's a 'classical' way.
Using : ZoomObjects(ids)
private void ZoomObjects(ObjectId[] ids)
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
using (ViewTableRecord view = ed.GetCurrentView())
Matrix3d WCS2DCS =
(Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
Matrix3d.Displacement(view.Target - Point3d.Origin) *
Matrix3d.PlaneToWorld(view.ViewDirection))
.Inverse();
Entity ent = (Entity)tr.GetObject(ids[0], OpenMode.ForRead);
Extents3d ext = ent.GeometricExtents;
for (int i = 1; i < ids.Length; i++)
ent = (Entity)tr.GetObject(ids[i], OpenMode.ForRead);
ext.AddExtents(ent.GeometricExtents);
ext.TransformBy(WCS2DCS);
view.Width = ext.MaxPoint.X - ext.MinPoint.X;
view.Height = ext.MaxPoint.Y - ext.MinPoint.Y;
view.CenterPoint =
new Point2d((ext.MaxPoint.X + ext.MinPoint.X) / 2.0, (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0);
ed.SetCurrentView(view);
tr.Commit();
Here's a more generic one using extension methods for the Editor type (others zoom methods can be added to this class, calling or not the Editor.Zoom(Extents3d ext) one).
Using: ed.ZoomObjects(ids) // ids may be any type implementing IEnumerabe<ObjectId>
static class ZoomExtensions
// Returns the transformation matrix from the ViewTableRecord DCS to WCS
public static Matrix3d EyeToWorld(this ViewTableRecord view)
return
Matrix3d.PlaneToWorld(view.ViewDirection);
// Returns the transformation matrix from WCS to the ViewTableRecord DCS
public static Matrix3d WorldToEye(this ViewTableRecord view)
return view.EyeToWorld().Inverse();
// Process a zoom according to the extents3d in the current viewport
public static void Zoom(this Editor ed, Extents3d ext)
ext.TransformBy(view.WorldToEye());
view.CenterPoint = new Point2d(
// Process a zoom objects in the current viewport
public static void ZoomObjects(this Editor ed, IEnumerable<ObjectId> ids)
using (Transaction tr = ed.Document.TransactionManager.StartTransaction())
Extents3d ext = ids
.Select(id => ((Entity)tr.GetObject(id, OpenMode.ForRead)).GeometricExtents)
.Aggregate((e1, e2) => { e1.AddExtents(e2); return e1; });
ed.Zoom(ext);
tr.Commit();
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried to add object to the db and it did not work.
Thanks. It helped me lot.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry I do not understand what you mean: "I tried to add object to the db and it did not work."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your solution works well for me. What I had tried before posting this in the forum was the one below, which did not work. I was in the wrong track.
Thanks.
Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction(); using (tr) { foreach (Autodesk.AutoCAD.DatabaseServices.ObjectId oId in oidList) { DBObject obj = tr.GetObject(oId, OpenMode.ForRead); db.AddDBObject(obj); } tr.Commit(); } Editor editor = Application.DocumentManager.MdiActiveDocument.Edit or; ViewTableRecord view = new ViewTableRecord(); Point3d center = db.Extmin + ((db.Extmax - db.Extmin) / 2); view.CenterPoint = new Autodesk.AutoCAD.Geometry.Point2d(center.X, center.Y); view.Height = db.Extmax.Y - db.Extmin.Y; view.Width = db.Extmax.X - db.Extmin.X; editor.SetCurrentView(view);
