• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Keith.Brown
    Write to command line more than once during a command using editor.writeline
    318 Views, 12 Replies
    01-28-2012 04:19 PM
    I am using editor.writeline to send information to the command line during the execution of a command.  Unfortunately, it will only display the last message written when the command ends.  Is there a way to display all the messages when the command ends?  Below is the code that I am using.  I am new to vb.net in general and in programming autocad so if you see anything that can be done better in the code please let me know.  Thanks in advance.
            Public Sub CreateVentilationLayers()
                CreateTrimbleLayer(VENT375)
                CreateTrimbleLayer(VENT500)
                CreateTrimbleLayer(VENT625)
                CreateTrimbleLayer(VENT750)
                CreateTrimbleLayer(VENT875)
            End Sub
            Public Sub CreateTrimbleLayer(ByVal LayerName)
                Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
                Dim myDB As Database = HostApplicationServices.WorkingDatabase
                Try
                    Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
                        Dim myLayerTable As LayerTable = myDB.LayerTableId.GetObject(OpenMode.ForWrite)
                        Dim myLayer As New LayerTableRecord
                        myLayer.Name = LayerName
                        myLayer.Color = Colors.Color.FromColor(Drawing.Color.White)
                        myLayer.LineWeight = LineWeight.LineWeight050
                        myLayerTable.Add(myLayer)
                        myLayer.Description = LayerName
                        myTrans.AddNewlyCreatedDBObject(myLayer, True)
                        myTrans.Commit()
                        ed.WriteMessage(LayerName + " layer created..." + Chr(13))
                    End Using
                Catch ex As Exception
                    ed.WriteMessage(LayerName + " not created..." + Chr(13))
                End Try
            End Sub
    Keith Brown AutoCAD MEP BLOG | RSS Feed
    Please use plain text.
    Keith.Brown
    Re: Write to command line more than once during a command using editor.writeline
    01-28-2012 05:44 PM in reply to: Keith.Brown
    Also, the following line:
    will show as 255,255,255 under color in the layer manager.  How do I get it to show white?
    Valued Mentor
    KerryBrown
    01-28-2012 05:52 PM in reply to: Keith.Brown
    What Type or parameter are you passing to the Sub ... is it meant to be a String ??
    class keyThumper<T> : Lazy<T>;      another  Swamper
    I do not endorse the social media app links below:smileyembarrassed:
    Keith.Brown
    01-28-2012 05:54 PM in reply to: KerryBrown
    Yes,  the parameters are strings that are defined as constants.  I just wanted one place to modify layer names if I had to.  I will give the code a try and see if it works for me.
    Valued Mentor
    KerryBrown
    01-28-2012 05:58 PM in reply to: Keith.Brown
    Fourth try at posting the code ... I'm technologically challenged :smileyhappy:
    Perhaps Convert this and have a play
    using System;
    using System.Windows.Media;
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.Colors;
    using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
    using AcColors = Autodesk.AutoCAD.Colors;
    [assembly: CommandClass(typeof (CreateVentilation.MyCommands))]
    namespace CreateVentilation
        public class MyCommands
            // Modal Command with localized name
            [CommandMethod("Test02", CommandFlags.Modal)]
            public void CreateVentilationLayers()
                CreateTrimbleLayer("VENT375", 0);
                CreateTrimbleLayer("VENT500", 1);
                CreateTrimbleLayer("VENT625", 2);
                CreateTrimbleLayer("VENT750", 3);
                CreateTrimbleLayer("VENT875", 4);
            public void CreateTrimbleLayer(string layerName, short colorNum)
                var doc = AcadApp.DocumentManager.MdiActiveDocument;
                var db = doc.Database;
                var ed = doc.Editor;
                try
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        var lt = (LayerTable) db.LayerTableId.GetObject(OpenMode.ForWrite);
                        if (lt.Has(layerName))
                            ed.WriteMessage(layerName + " exists...\n");
                            return;
                        var ltr = new LayerTableRecord();
                        ltr.Name = layerName;
                        ltr.Color = AcColors.Color.FromColorIndex(ColorMethod.ByAci,
        colorNum);
                        ltr.LineWeight = LineWeight.LineWeight050;
                        lt.Add(ltr);
                        ltr.Description = layerName;
                        tr.AddNewlyCreatedDBObject(ltr, true);
                        tr.Commit();
                        ed.WriteMessage(layerName + " layer created...\n");
                catch (Autodesk.AutoCAD.Runtime.Exception)
                    ed.WriteMessage(layerName + " Ooooops ; not created...\n");
    Keith.Brown
    01-28-2012 06:18 PM in reply to: KerryBrown
    Ok, that worked perfect.  Would you mind explaining why so I can use this as a learning experience?   Below is the final code that I used.
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.Colors
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.ApplicationServices.Application
    Imports Autodesk.AutoCAD.LayerManager
    Imports Autodesk.AutoCAD.Windows
    Imports Autodesk.Aec.Building.Piping.DatabaseServices
    Imports AecBPropDB = Autodesk.Aec.PropertyData.DatabaseServices
    Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
    Imports AcColors = Autodesk.AutoCAD.Colors
    Namespace Trimble
        Public Class Trimble
    #Region "Constants"
            Private Const HYD375 As String = "Trimble-Hyd-Insert-0.375"
            Private Const HYD500 As String = "Trimble-Hyd-Insert-0.500"
            Private Const HYD625 As String = "Trimble-Hyd-Insert-0.625"
            Private Const HYD750 As String = "Trimble-Hyd-Insert-0.750"
            Private Const HYD875 As String = "Trimble-Hyd-Insert-0.875"
            Private Const HYDSLV As String = "Trimble-Hyd-Sleeve"
            Private Const HYDSLVDIM As String = "Trimble-Hyd-Sleeve-Dim"
            Private Const HYDSLVTEXT As String = "Trimble-Hyd-Sleeve-Text"
            Private Const HYDSYS As String = "Trimble-Hyd-System"
            Private Const PLBG375 As String = "Trimble-Plbg-Insert-0.375"
            Private Const PLBG500 As String = "Trimble-Plbg-Insert-0.500"
            Private Const PLBG625 As String = "Trimble-Plbg-Insert-0.625"
            Private Const PLBG750 As String = "Trimble-Plbg-Insert-0.750"
            Private Const PLBG875 As String = "Trimble-Plbg-Insert-0.875"
            Private Const PLBGSLV As String = "Trimble-Plbg-Sleeve"
            Private Const PLBGSLVDIM As String = "Trimble-Plbg-Sleeve-Dim"
            Private Const PLBGSLVTEXT As String = "Trimble-Plbg-Sleeve-Text"
            Private Const PLBGSYS As String = "Trimble-Plbg-System"
            Private Const VENT375 As String = "Trimble-Vent-Insert-0.375"
            Private Const VENT500 As String = "Trimble-Vent-Insert-0.500"
            Private Const VENT625 As String = "Trimble-Vent-Insert-0.625"
            Private Const VENT750 As String = "Trimble-Vent-Insert-0.750"
            Private Const VENT875 As String = "Trimble-Vent-Insert-0.875"
            Private Const VENTSLV As String = "Trimble-Vent-Sleeve"
            Private Const VENTSLVDIM As String = "Trimble-Vent-Sleeve-Dim"
            Private Const VENTSLVTEXT As String = "Trimble-Vent-Sleeve-Text"
            Private Const VENTSYS As String = "Trimble-Vent-System"
            Private Const GRID As String = "Trimble-Plans-Grid"
            Private Const ARCH As String = "Trimble-Plans-Arch"
            Private Const STRUC As String = "Trimble-Plans-Struc"
            Private Const CONTROL As String = "Trimble-Control-Points"
    #End Region
    #Region "Commands"
            <CommandMethod("Trimblelayersadd")> _
            Public Sub AddTrimbleLayers()
                Dim GetLayerOptions As PromptKeywordOptions = New PromptKeywordOptions("Which Trimble Layers do you want to add? [Hydronics/Plumbing/Ventilation/All]: ", "Hydronics Plumbing Ventilation All")
                Dim GetLayerResults As PromptResult = ed.GetKeywords(GetLayerOptions)
                If (GetLayerResults.Status = PromptStatus.OK) Then
                    Select Case GetLayerResults.StringResult
                        Case "Hydronics"
                            CreateHydronicLayers()
                            CreateMiscLayers()
                        Case "Plumbing"
                            CreatePlumbingLayers()
                            CreateMiscLayers()
                        Case "Ventilation"
                            CreateMiscLayers()
                        Case "All"
                            CreateAllLayers()
                            CreateMiscLayers()
                    End Select
                End If
            End Sub
            <CommandMethod("TrimblePlumbingLayersAdd")> _
            Public Sub AddTrimblePlumbingLayers()
                CreateMiscLayers()
            End Sub
            <CommandMethod("TrimbleHydronicsLayersAdd")> _
            Public Sub AddTrimbleHydronicsLayers()
                CreateMiscLayers()
            End Sub
            <CommandMethod("TrimbleVentilationLayersAdd")> _
            Public Sub AddTrimbleVentiliationLayers()
                CreateMiscLayers()
            End Sub
            <CommandMethod("TrimbleAllLayersAdd")> _
            Public Sub AddTrimbleAllLayers()
                CreateMiscLayers()
            End Sub
    #End Region
    #Region "Helper Functions"
            Public Sub CreateAllLayers()
                CreateMiscLayers()
            End Sub
            Public Sub CreatePlumbingLayers()
                CreateTrimbleLayer(PLBG375, 0)
                CreateTrimbleLayer(PLBG500, 0)
                CreateTrimbleLayer(PLBG625, 0)
                CreateTrimbleLayer(PLBG750, 0)
                CreateTrimbleLayer(PLBG875, 0)
                CreateTrimbleLayer(PLBGSLV, 0)
                CreateTrimbleLayer(PLBGSLVDIM, 0)
                CreateTrimbleLayer(PLBGSLVTEXT, 0)
                CreateTrimbleLayer(PLBGSYS, 0)
            End Sub
            Public Sub CreateHydronicLayers()
                CreateTrimbleLayer(HYD375, 0)
                CreateTrimbleLayer(HYD500, 0)
                CreateTrimbleLayer(HYD625, 0)
                CreateTrimbleLayer(HYD750, 0)
                CreateTrimbleLayer(HYD875, 0)
                CreateTrimbleLayer(HYDSLV, 0)
                CreateTrimbleLayer(HYDSLVDIM, 0)
                CreateTrimbleLayer(HYDSLVTEXT, 0)
                CreateTrimbleLayer(HYDSYS, 0)
            End Sub
                CreateTrimbleLayer(VENT375, 0)
                CreateTrimbleLayer(VENT500, 0)
                CreateTrimbleLayer(VENT625, 0)
                CreateTrimbleLayer(VENT750, 0)
                CreateTrimbleLayer(VENT875, 0)
                CreateTrimbleLayer(VENTSLV, 0)
                CreateTrimbleLayer(VENTSLVDIM, 0)
                CreateTrimbleLayer(VENTSLVTEXT, 0)
                CreateTrimbleLayer(VENTSYS, 0)
            End Sub
            Public Sub CreateMiscLayers()
                CreateTrimbleLayer(GRID, 0)
                CreateTrimbleLayer(ARCH, 0)
                CreateTrimbleLayer(STRUC, 0)
                CreateTrimbleLayer(CONTROL, 0)
            End Sub
            Public Sub CreateTrimbleLayer(layerName As String, colorNum As Short)
                Dim doc = AcApp.DocumentManager.MdiActiveDocument
                Dim db = doc.Database
                Dim ed = doc.Editor
                Try
                    Using tr As Transaction = db.TransactionManager.StartTransaction()
                        Dim lt = DirectCast(db.LayerTableId.GetObject(OpenMode.ForWrite), LayerTable)
                        If lt.Has(layerName) Then
                            ed.WriteMessage(layerName & " exists..." & vbLf)
                            Return
                        End If
                        Dim ltr = New LayerTableRecord()
                        ltr.Color = AcColors.Color.FromColorIndex(ColorMethod.ByAci, colorNum)
                        lt.Add(ltr)
                        tr.AddNewlyCreatedDBObject(ltr, True)
                        tr.Commit()
                        ed.WriteMessage(layerName & " layer created..." & vbLf)
                    End Using
                Catch generatedExceptionName As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(layerName & " Ooooops ; not created..." & vbLf)
                End Try
            End Sub
    #End Region
        End Class
    End Namespace
    Valued Mentor
    KerryBrown
    01-28-2012 06:46 PM in reply to: Keith.Brown
    Sorry, no ... my brain stops working when I try to debug VB.
    Keith.Brown
    01-28-2012 07:50 PM in reply to: KerryBrown
    The only difference I see is the way that i was creating my database object.  I used the way that was outlined inside of Jerry Winter's VB book.  I will start using the way you defined yours.
    BrentBurgess1980
    01-29-2012 03:55 PM in reply to: Keith.Brown
    The one difference stands out to me is that Kerry performs a check to see if the layer exists, and as you mentioned the way the db is created.
    Valued Mentor
    KerryBrown
    01-29-2012 07:19 PM in reply to: Keith.Brown
    Something else to consider ..
    You may want to pass the LineWeight enumerator to
    CreateTrimbleLayer()
    .. This will allow your generic layer builder to set the Lineweight from the enumerator instead of having each Layer use the Hardcoded LineWeight.
    kdub
