.NET
Keith.Brown
Message 1 of 13 (634 Views)
Write to command line more than once during a command using editor.writeline
634 Views, 12 Replies
01-28-2012 04:19 PM
I am using editor.writeline to send information to the command line during the execution of a command.  Unfortunately, it will only display the last message written when the command ends.  Is there a way to display all the messages when the command ends?  Below is the code that I am using.  I am new to vb.net in general and in programming autocad so if you see anything that can be done better in the code please let me know.  Thanks in advance.
        Public Sub CreateVentilationLayers()
            CreateTrimbleLayer(VENT375)
            CreateTrimbleLayer(VENT500)
            CreateTrimbleLayer(VENT625)
            CreateTrimbleLayer(VENT750)
            CreateTrimbleLayer(VENT875)
        End Sub
        Public Sub CreateTrimbleLayer(ByVal LayerName)
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim myDB As Database = HostApplicationServices.WorkingDatabase
            Try
                Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
                    Dim myLayerTable As LayerTable = myDB.LayerTableId.GetObject(OpenMode.ForWrite)
                    Dim myLayer As New LayerTableRecord
                    myLayer.Name = LayerName
                    myLayer.Color = Colors.Color.FromColor(Drawing.Color.White)
                    myLayer.LineWeight = LineWeight.LineWeight050
                    myLayerTable.Add(myLayer)
                    myLayer.Description = LayerName
                    myTrans.AddNewlyCreatedDBObject(myLayer, True)
                    myTrans.Commit()
                    ed.WriteMessage(LayerName + " layer created..." + Chr(13))
                End Using
            Catch ex As Exception
                ed.WriteMessage(LayerName + " not created..." + Chr(13))
            End Try
        End Sub
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Keith.Brown
Message 2 of 13 (626 Views)
Re: Write to command line more than once during a command using editor.writeline
01-28-2012 05:44 PM in reply to: Keith.Brown
Also, the following line:
will show as 255,255,255 under color in the layer manager.  How do I get it to show white?
Valued Mentor
KerryBrown
Message 3 of 13 (624 Views)
01-28-2012 05:52 PM in reply to: Keith.Brown
What Type or parameter are you passing to the Sub ... is it meant to be a String ??
class keyThumper<T> : Lazy<T>;      another  Swamper
Keith.Brown
Message 4 of 13 (621 Views)
01-28-2012 05:54 PM in reply to: KerryBrown
Yes,  the parameters are strings that are defined as constants.  I just wanted one place to modify layer names if I had to.  I will give the code a try and see if it works for me.
Valued Mentor
KerryBrown
Message 5 of 13 (618 Views)
01-28-2012 05:58 PM in reply to: Keith.Brown
Fourth try at posting the code ... I'm technologically challenged :smileyhappy:
Perhaps Convert this and have a play
using System;
using System.Windows.Media;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Colors;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcColors = Autodesk.AutoCAD.Colors;
[assembly: CommandClass(typeof (CreateVentilation.MyCommands))]
namespace CreateVentilation
    public class MyCommands
        // Modal Command with localized name
        [CommandMethod("Test02", CommandFlags.Modal)]
        public void CreateVentilationLayers()
            CreateTrimbleLayer("VENT375", 0);
            CreateTrimbleLayer("VENT500", 1);
            CreateTrimbleLayer("VENT625", 2);
            CreateTrimbleLayer("VENT750", 3);
            CreateTrimbleLayer("VENT875", 4);
        public void CreateTrimbleLayer(string layerName, short colorNum)
            var doc = AcadApp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    var lt = (LayerTable) db.LayerTableId.GetObject(OpenMode.ForWrite);
                    if (lt.Has(layerName))
                        ed.WriteMessage(layerName + " exists...\n");
                        return;
                    var ltr = new LayerTableRecord();
                    ltr.Name = layerName;
                    ltr.Color = AcColors.Color.FromColorIndex(ColorMethod.ByAci,
                                                              colorNum);
                    ltr.LineWeight = LineWeight.LineWeight050;
                    lt.Add(ltr);
                    ltr.Description = layerName;
                    tr.AddNewlyCreatedDBObject(ltr, true);
                    tr.Commit();
                    ed.WriteMessage(layerName + " layer created...\n");
            catch (Autodesk.AutoCAD.Runtime.Exception)
                ed.WriteMessage(layerName + " Ooooops ; not created...\n");
Keith.Brown
Message 6 of 13 (606 Views)
01-28-2012 06:18 PM in reply to: KerryBrown
Ok, that worked perfect.  Would you mind explaining why so I can use this as a learning experience?   Below is the final code that I used.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.LayerManager
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.Aec.Building.Piping.DatabaseServices
Imports AecBPropDB = Autodesk.Aec.PropertyData.DatabaseServices
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports AcColors = Autodesk.AutoCAD.Colors
Namespace Trimble
    Public Class Trimble
#Region "Constants"
        Private Const HYD375 As String = "Trimble-Hyd-Insert-0.375"
        Private Const HYD500 As String = "Trimble-Hyd-Insert-0.500"
        Private Const HYD625 As String = "Trimble-Hyd-Insert-0.625"
        Private Const HYD750 As String = "Trimble-Hyd-Insert-0.750"
        Private Const HYD875 As String = "Trimble-Hyd-Insert-0.875"
        Private Const HYDSLV As String = "Trimble-Hyd-Sleeve"
        Private Const HYDSLVDIM As String = "Trimble-Hyd-Sleeve-Dim"
        Private Const HYDSLVTEXT As String = "Trimble-Hyd-Sleeve-Text"
        Private Const HYDSYS As String = "Trimble-Hyd-System"
        Private Const PLBG375 As String = "Trimble-Plbg-Insert-0.375"
        Private Const PLBG500 As String = "Trimble-Plbg-Insert-0.500"
        Private Const PLBG625 As String = "Trimble-Plbg-Insert-0.625"
        Private Const PLBG750 As String = "Trimble-Plbg-Insert-0.750"
        Private Const PLBG875 As String = "Trimble-Plbg-Insert-0.875"
        Private Const PLBGSLV As String = "Trimble-Plbg-Sleeve"
        Private Const PLBGSLVDIM As String = "Trimble-Plbg-Sleeve-Dim"
        Private Const PLBGSLVTEXT As String = "Trimble-Plbg-Sleeve-Text"
        Private Const PLBGSYS As String = "Trimble-Plbg-System"
        Private Const VENT375 As String = "Trimble-Vent-Insert-0.375"
        Private Const VENT500 As String = "Trimble-Vent-Insert-0.500"
        Private Const VENT625 As String = "Trimble-Vent-Insert-0.625"
        Private Const VENT750 As String = "Trimble-Vent-Insert-0.750"
        Private Const VENT875 As String = "Trimble-Vent-Insert-0.875"
        Private Const VENTSLV As String = "Trimble-Vent-Sleeve"
        Private Const VENTSLVDIM As String = "Trimble-Vent-Sleeve-Dim"
        Private Const VENTSLVTEXT As String = "Trimble-Vent-Sleeve-Text"
        Private Const VENTSYS As String = "Trimble-Vent-System"
        Private Const GRID As String = "Trimble-Plans-Grid"
        Private Const ARCH As String = "Trimble-Plans-Arch"
        Private Const STRUC As String = "Trimble-Plans-Struc"
        Private Const CONTROL As String = "Trimble-Control-Points"
#End Region
#Region "Commands"
        <CommandMethod("Trimblelayersadd")> _
        Public Sub AddTrimbleLayers()
            Dim GetLayerOptions As PromptKeywordOptions = New PromptKeywordOptions("Which Trimble Layers do you want to add? [Hydronics/Plumbing/Ventilation/All]: ", "Hydronics Plumbing Ventilation All")
            Dim GetLayerResults As PromptResult = ed.GetKeywords(GetLayerOptions)
            If (GetLayerResults.Status = PromptStatus.OK) Then
                Select Case GetLayerResults.StringResult
                    Case "Hydronics"
                        CreateHydronicLayers()
                        CreateMiscLayers()
                    Case "Plumbing"
                        CreatePlumbingLayers()
                        CreateMiscLayers()
                    Case "Ventilation"
                        CreateMiscLayers()
                    Case "All"
                        CreateAllLayers()
                        CreateMiscLayers()
                End Select
            End If
        End Sub
        <CommandMethod("TrimblePlumbingLayersAdd")> _
        Public Sub AddTrimblePlumbingLayers()
            CreateMiscLayers()
        End Sub
        <CommandMethod("TrimbleHydronicsLayersAdd")> _
        Public Sub AddTrimbleHydronicsLayers()
            CreateMiscLayers()
        End Sub
        <CommandMethod("TrimbleVentilationLayersAdd")> _
        Public Sub AddTrimbleVentiliationLayers()
            CreateMiscLayers()
        End Sub
        <CommandMethod("TrimbleAllLayersAdd")> _
        Public Sub AddTrimbleAllLayers()
            CreateMiscLayers()
        End Sub
#End Region
#Region "Helper Functions"
        Public Sub CreateAllLayers()
            CreateMiscLayers()
        End Sub
        Public Sub CreatePlumbingLayers()
            CreateTrimbleLayer(PLBG375, 0)
            CreateTrimbleLayer(PLBG500, 0)
            CreateTrimbleLayer(PLBG625, 0)
            CreateTrimbleLayer(PLBG750, 0)
            CreateTrimbleLayer(PLBG875, 0)
            CreateTrimbleLayer(PLBGSLV, 0)
            CreateTrimbleLayer(PLBGSLVDIM, 0)
            CreateTrimbleLayer(PLBGSLVTEXT, 0)
            CreateTrimbleLayer(PLBGSYS, 0)
        End Sub
        Public Sub CreateHydronicLayers()
            CreateTrimbleLayer(HYD375, 0)
            CreateTrimbleLayer(HYD500, 0)
            CreateTrimbleLayer(HYD625, 0)
            CreateTrimbleLayer(HYD750, 0)
            CreateTrimbleLayer(HYD875, 0)
            CreateTrimbleLayer(HYDSLV, 0)
            CreateTrimbleLayer(HYDSLVDIM, 0)
            CreateTrimbleLayer(HYDSLVTEXT, 0)
            CreateTrimbleLayer(HYDSYS, 0)
        End Sub
            CreateTrimbleLayer(VENT375, 0)
            CreateTrimbleLayer(VENT500, 0)
            CreateTrimbleLayer(VENT625, 0)
            CreateTrimbleLayer(VENT750, 0)
            CreateTrimbleLayer(VENT875, 0)
            CreateTrimbleLayer(VENTSLV, 0)
            CreateTrimbleLayer(VENTSLVDIM, 0)
            CreateTrimbleLayer(VENTSLVTEXT, 0)
            CreateTrimbleLayer(VENTSYS, 0)
        End Sub
        Public Sub CreateMiscLayers()
            CreateTrimbleLayer(GRID, 0)
            CreateTrimbleLayer(ARCH, 0)
            CreateTrimbleLayer(STRUC, 0)
            CreateTrimbleLayer(CONTROL, 0)
        End Sub
        Public Sub CreateTrimbleLayer(layerName As String, colorNum As Short)
            Dim doc = AcApp.DocumentManager.MdiActiveDocument
            Dim db = doc.Database
            Dim ed = doc.Editor
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Dim lt = DirectCast(db.LayerTableId.GetObject(OpenMode.ForWrite), LayerTable)
                    If lt.Has(layerName) Then
                        ed.WriteMessage(layerName & " exists..." & vbLf)
                        Return
                    End If
                    Dim ltr = New LayerTableRecord()
                    ltr.Color = AcColors.Color.FromColorIndex(ColorMethod.ByAci, colorNum)
                    lt.Add(ltr)
                    tr.AddNewlyCreatedDBObject(ltr, True)
                    tr.Commit()
                    ed.WriteMessage(layerName & " layer created..." & vbLf)
                End Using
            Catch generatedExceptionName As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(layerName & " Ooooops ; not created..." & vbLf)
            End Try
        End Sub
#End Region
    End Class
End Namespace
Valued Mentor
KerryBrown
Message 7 of 13 (600 Views)
01-28-2012 06:46 PM in reply to: Keith.Brown
Sorry, no ... my brain stops working when I try to debug VB.
Keith.Brown
Message 8 of 13 (594 Views)
01-28-2012 07:50 PM in reply to: KerryBrown
The only difference I see is the way that i was creating my database object.  I used the way that was outlined inside of Jerry Winter's VB book.  I will start using the way you defined yours.
BrentBurgess1980
Message 9 of 13 (569 Views)
01-29-2012 03:55 PM in reply to: Keith.Brown
The one difference stands out to me is that Kerry performs a check to see if the layer exists, and as you mentioned the way the db is created.
Valued Mentor
KerryBrown
Message 10 of 13 (562 Views)
01-29-2012 07:19 PM in reply to: Keith.Brown
Something else to consider ..
You may want to pass the LineWeight enumerator to
CreateTrimbleLayer()
.. This will allow your generic layer builder to set the Lineweight from the enumerator instead of having each Layer use the Hardcoded LineWeight.
kdub
You are not logged in.
Ask the Community
