.NET
Working in PaperSpace
5 REPLIES 5
476 Views, 5 Replies
      Dim acDoc As Document
      Dim acCurDb As Database
      Dim acBlkTbl As BlockTable
      Dim acBlkTblRec As BlockTableRecord
      Dim acText As DBText = New DBText()
      acDoc = Application.DocumentManager.MdiActiveDocument
      acCurDb = acDoc.Database
      Using acLckDoc As DocumentLock = acDoc.LockDocument
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
          acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
          acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
          acText = New DBText()
          acText.Position = New Point3d(31.5359, 2.5536, 0)
          acBlkTblRec.AppendEntity(acText)
          acTrans.AddNewlyCreatedDBObject(acText, True)
          acTrans.Commit()
        End Using
        acDoc.Editor.UpdateScreen()
      End Using
I'm trying to fill out a sheet stocklist in paperspace. What is the trick to get the new text object located in the proper place? When I run the attached code, the text always is located at 0,0,0. Is there an offset I need to apply?
5 REPLIES 5
khoa.ho
Your code looks right to insert the text at a specified position in the first layout of paper space. I don't know why your text is located at (0, 0, 0). You may post your detailed code to help to see the problem.
-Khoa
    Public Shared Sub New_Text(ByVal acObjIdColl As ObjectIdCollection, ByVal sSpace As String, ByVal Text_Location As Point3d, _
                               ByVal Text_Height As Double, ByVal Text_String As String, ByVal Layer As String, ByVal Text_Style As String, _
                               ByVal Color As String, ByVal Justification As String, ByVal Vertical_Alignment As String)
        Application.SetSystemVariable("CLAYER", Layer)
        Application.SetSystemVariable("TEXTSTYLE", Text_Style)
        Application.SetSystemVariable("CECOLOR", Color)
        '' Start a transaction
          '' Open the Block table for read
          '' Open the Block table record Model space for write
          If sSpace = "Model" Then
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
          Else
          acText.SetDatabaseDefaults()
          acText.Position = Text_Location
          acText.Height = Text_Height
          acText.TextString = Text_String
          Select Case LCase(Justification)
            Case "right"
              If LCase(Vertical_Alignment) = "middle" Then
                acText.HorizontalMode = TextHorizontalMode.TextRight
                acText.VerticalMode = TextVerticalMode.TextVerticalMid
              Else
            Case "center"
                acText.HorizontalMode = TextHorizontalMode.TextCenter
              Else
            Case "left"
                acText.HorizontalMode = TextHorizontalMode.TextLeft
              Else
          End Select
          '' Save the changes and dispose of the transaction
          acTrans.Commit()
        End Using
      End Using
    End Sub
Thank you for the response Khoa.
Here is the complete Sub.
I'm able to insert the frame work of the Stock list in the correct location. I don't understand the problem with the Text.
Brian
khoa.ho
Hi Brian,
Sorry for a bit lag. I don't have a chance to test your code yet. I will check it again after work.
-Khoa
khoa.ho
Hi Brian,
AutoCAD uses DBText.AlignmentPoint property to adjust alignment of a text if it is not horizontal left (TextHorizontalMode.TextLeft) and vertical base (TextVerticalMode.TextBase) by default.
DBText.Position defines a text insertion point while DBText.AlignmentPoint defines its alignment point. They are different. AlignmentPoint does not need to set (it will get default value 0,0,0), if the text is default horizontal left and vertical base (it will fail if we try to change AlignmentPoint at this time).
If we change horizontal and vertical alignments to be different with their default values, the Position property (lower left point of the text) becomes useless because it will be different depending on text height and width. Instead, we need to set AlignmentPoint property. The AlignmentPoint will be the text location at this time.
The problem is that the text is always at (0, 0, 0) point regardless of any DBText.Position because this text has alignment properties different with its default values.
So you just need to add acText.AlignmentPoint = Text_Location after modifying horizontal and vertical modes. I rewrite your code (in C#) with a test method to add texts in both Model and Paper spaces. The issue is the text alignment, not belongs to Paper space.
[CommandMethod("New_Text")]
public static void New_Text()
    New_Text(null, "Model", new Point3d(5, 10, 0), 2, "My model text", "0", "Standard", "2", "center", "middle");
    New_Text(null, "Layout", new Point3d(5, 10, 0), 2, "My paper text", "0", "Standard", "3", "left", "middle");
public static void New_Text(ObjectIdCollection acObjIdColl, string sSpace, Point3d Text_Location, double Text_Height,
                            string Text_String, string Layer, string Text_Style, string Color, string Justification,
                            string Vertical_Alignment)
    Document acDoc = Application.DocumentManager.MdiActiveDocument;
    Database acCurDb = acDoc.Database;
    using (DocumentLock acLckDoc = acDoc.LockDocument())
        Application.SetSystemVariable("CLAYER", Layer);
        Application.SetSystemVariable("TEXTSTYLE", Text_Style);
        Application.SetSystemVariable("CECOLOR", Color);
        // Start a transaction
        using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
            // Open the Block table for read
            BlockTable acBlkTbl = (BlockTable)acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead);
            // Open the Block table record Model space for write
            BlockTableRecord acBlkTblRec;
            if ((sSpace == "Model"))
                acBlkTblRec = (BlockTableRecord)acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
            else
                acBlkTblRec = (BlockTableRecord)acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace], OpenMode.ForWrite);
            DBText acText = new DBText();
            acText.SetDatabaseDefaults();
            acText.Position = Text_Location;
            acText.Height = Text_Height;
            acText.TextString = Text_String;
            acBlkTblRec.AppendEntity(acText);
            switch (Justification.ToLower())
                case "right":
                    if ((Vertical_Alignment.ToLower() == "middle"))
                        acText.HorizontalMode = TextHorizontalMode.TextRight;
                        acText.VerticalMode = TextVerticalMode.TextVerticalMid;
                    else
                    break;
                case "center":
                        acText.HorizontalMode = TextHorizontalMode.TextCenter;
                    else
                    break;
                case "left":
                        acText.HorizontalMode = TextHorizontalMode.TextLeft;
                    else
                    break;
            acText.AlignmentPoint = Text_Location;
            acTrans.AddNewlyCreatedDBObject(acText, true);
            // Save the changes and dispose of the transaction
            acTrans.Commit();
-Khoa
_gile
in reply to: khoa.ho
By my side, I use a SetPosition() extension method for the DBText type. This method takes care of setting AlignmentPoint according to the text Justification.
C#
    public static class DBTextExtension
        public static void SetPosition(this DBText text, Point3d pt, AttachmentPoint justif)
            text.Position = pt;
            text.Justify = justif;
            if (text.HorizontalMode != TextHorizontalMode.TextLeft ||
                text.VerticalMode != TextVerticalMode.TextBase)
                text.AlignmentPoint = pt;
                text.AdjustAlignment(HostApplicationServices.WorkingDatabase);
F#
type DBText with
    member txt.SetPosition(pt, justif) =
        txt.Position <- pt
        txt.Justify <- justif
        if txt.HorizontalMode <> TextHorizontalMode.TextLeft ||
            txt.VerticalMode <> TextVerticalMode.TextBase then
            txt.AlignmentPoint <- pt
            txt.AdjustAlignment(HostApplicationServices.WorkingDatabase)
VB
    Module DBTextExtensions
        <System.Runtime.CompilerServices.Extension()> _
        Public Sub SetPosition(ByVal text As DBText, ByVal pt As Point3d, ByVal justif As AttachmentPoint)
            text.Position = pt
            If text.HorizontalMode <> TextHorizontalMode.TextLeft OrElse _
                text.VerticalMode <> TextVerticalMode.TextBase Then
        End Sub
    End Module
Gilles Chanteau
GileCAD
GitHub
”Boost
