.NET
Distinguished Contributor
fxcastil
Message 1 of 3 (333 Views)
Accepted Solution
Windows Form Application vs Class Library Application and Userform Scope
333 Views, 2 Replies
08-13-2012 12:57 PM
I created a Windows Form application and Class Library application with one UserForm and One module.
Both type of applications should be the same.
I found this example about userforms in VB.net and VB.
It talks about userforms in Vb.net not having a global scope
But again (being redundant) the WindowsFormApplication.NET does have global scope of Userforms, but the ClassLibraryApplication.Net does not have global scope of Userforms.
http://msdn.microsoft.com/en-us/library/aa289529(v=VS.71).aspx
'''''''''''''''''  a module in the sample programs attached  '''''''''''''''''''
Option Explicit On
Option Strict On
Module Mod_Test
    Sub test()
' I can type/use this in the WindowsFormApplication but not the
' I can NOT type/use this in the ClassLibraryApplication
        formTest.TextBox1.Text = "hello"
    End Sub
End Module
Valued Mentor
jeff
Message 2 of 3 (326 Views)
Re: Windows Form Application vs Class Library Application and Userform Scope
08-13-2012 01:42 PM in reply to: fxcastil
Never new that but the typing the name of a Form class in WindowForms apps creates a shortcut to MyProject.Forms.formName
and the difference is a class library does not have Forms property exposed in MY object explained in link
http://www.theswamp.org/index.php?topic=42464.msg476788#msg476788
You can also find your answers @ TheSwamp
fxcastil
Message 3 of 3 (319 Views)
08-13-2012 01:47 PM in reply to: jeff
Jeff,
Thanks ........I Learned something new today.
You are not logged in.
Announcements
Need installation help?
Ask the Community
