Window.State is Error
classof
Message 1 of 9
classof
Hello~
I study dotnet.
so, I referenced "AutoCAD .NET Developer's Guide".
but, I have a problem. I don't know why.
below code has Error.
below code copied from "AutoCAD .NET Developer's Guide".
please help me.
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.Runtime;
using System.Drawing;
namespace ClassLibrary1
    public class Class1
        [CommandMethod("MinMaxApplicationWindow")]
        public static void MinMaxApplicationWindow()
            // Minimize the Application window
            Application.MainWindow.WindowState = Window.State.Minimized;  //Error
            System.Windows.Forms.MessageBox.Show("Minimized", "MinMax",
                        System.Windows.Forms.MessageBoxButtons.OK,
                        System.Windows.Forms.MessageBoxIcon.None,
                        System.Windows.Forms.MessageBoxDefaultButton.Button1,
                        System.Windows.Forms.MessageBoxOptions.ServiceNotification);
            // Maximize the Application window
            Application.MainWindow.WindowState = Window.State.Maximized;   //Error
            System.Windows.Forms.MessageBox.Show("Maximized", "MinMax");
Replies (8)
Message 2 of 9
Remove using System;
or
            Application.MainWindow.WindowState = Autodesk.AutoCAD.Windows.Window.State.Minimized;  //Error
            Application.MainWindow.WindowState = Autodesk.AutoCAD.Windows.Window.State.Maximized;   //Error
Message 3 of 9
Although when you build it the compiler should figure out which Window namespace you are refering to. So try building it first.
 System.Windows.Window
Message 4 of 9
classof
Jeffrey_H
thank you..
I followed your answer. so I removed "using system".  but not solved.
"Autodesk.AutoCAD.Windows.Window.  has not "State".
Autodesk.AutoCAD.Windows.Window.(ReferenceEquals / GetDeviceIndependentScale / Equals / Create)
It has not "State".
anyway thanks your reply.
Message 5 of 9
Have you tried compiling it. Press F6 or use the toolbar.
Message 6 of 9
chiefbraincloud
That code worked fine pasted into my project.  What version of AutoCAD are you using?
Message 7 of 9
classof
chiefbraincloud..
thaks your reply..
I have been using  AutoCad 2009 and "VS2008 express"
Message 8 of 9
chiefbraincloud
That is the problem.  In 2010 AutoCAD the Object Browser shows this:
WindowState() As Autodesk.AutoCAD.Windows.Window.State
but in 2009, it expects a:
System.Windows.Forms.FormWindowState
So if you change your code to use the System Enum, it will work.  (I tested it in 2009)
Message 9 of 9
classof
Wow~ thank you very much.. chiefbraincloud~
I did follow your reply. and then I solved my problem..
very thank youSmiley Happy
