• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    GrzesiekGP
    WinForm/WPF and AutoCAD 2007 & 2011.
    154 Views, 3 Replies
    03-20-2012 12:50 AM
    Hello!
    I have standalone application. With this app I'm startin an AutoCAD 2007.
      const string progID = "AutoCAD.Application.17";
                AcadApplication acApp = null;
                try
                    acApp = (AcadApplication)Marshal.GetActiveObject(progID);
                catch
                    try
                        Type acType = Type.GetTypeFromProgID(progID);
                        acApp = (AcadApplication)Activator.CreateInstance(acType, true);
                    catch
                        MessageBox.Show("Cannot create object of type \"" + progID + "\"");
                if (acApp != null)
                    // By the time this is reached AutoCAD is fully
                    // functional and can be interacted with through code
                    acApp.Visible = true;
                    acApp.ActiveDocument.SendCommand(....);
    I've added references to the AutoCAD 2007 Type Library and ObjectDBX (2007).
    But I want to have my application compatibile with AutoCAD 2011. With detection which AutoCAD is installed I don't have any problems.
    But how can I add the references depending on AutoCAD version? I tried to add both, but this is impossible.
    I was thinking about dynamically loading assemblies, but how can I then call AutoCAD and SendCommand?
    Thanks for the help.
    Please use plain text.
    Hallex
    Re: WinForm/WPF and AutoCAD 2007 & 2011.
    03-20-2012 01:59 AM in reply to: GrzesiekGP
    Type in the command lIne ACADVER
    you will be get a current version of your
    AutoCAD installed
    Valued Contributor
    GrzesiekGP
    03-20-2012 02:03 AM in reply to: Hallex
    With version detection I don't have problems as I said, but thanks.
    That's nice tricky command :smileywink:
    The question is about assemblies references and differents versions.
    Valued Contributor
    GrzesiekGP
    03-20-2012 08:18 AM in reply to: GrzesiekGP
    Or maybe other question:
    How can I send command to the autocad without declaring its version? So the code will be compatibile for both AC 2007 and 2011.
