.NET
Distinguished Contributor
wesbird
Message 1 of 4 (130 Views)
Why there is no Rotate and Rotate3d method in .NET
130 Views, 3 Replies
03-28-2006 12:21 PM
Hi
I found Rotate and Rotate3d both exist in VBA (ActiveX) and ObjectARX, but not in .NET?
Do I miss something in .NET?
How I rotate in 3d without COM Interop?
Thank you
Wes
jbooth
Message 2 of 4 (130 Views)
Re: Why there is no Rotate and Rotate3d method in .NET
03-28-2006 01:16 PM in reply to: wesbird
This is just a guess, but can't you create a rotation matrix and multiply it through?
Dim m As Matrix3d = Matrix3d.Rotation(angle, rotationVector, centrePoint)
For Each ent As Entity In objectsToRotate
ent.TransformBy(m)
Next ent
The reason they don't add the functionality is probably because you can do it easily enough yourself, (but only if you understand euclidean mathematics I guess).
*Nemorarius
Message 3 of 4 (130 Views)
03-28-2006 09:15 PM in reply to: wesbird
This way, it's not necessary for them to add anything at all, since you can
do everything yourself.
Why not write your own operating system and pay for it in the bargain?
wrote in message news:5124556@discussion.autodesk.com...
through?
ent.TransformBy(m)
Next ent
I guess).
ChrisArps
Message 4 of 4 (130 Views)
03-29-2006 06:10 AM in reply to: wesbird
Those have kinda been moved to the Matrix2d and Matrix3d classes. If you need to construct scaling/rotation/etc, you do that with the matrix then apply to the entities ecs.
Example : There is no "Move" method, but this shows how to do it.
Dim fromPt As Point3d
Dim toPt As Point3d
Dim ptRes As PromptPointResult
ptRes = editor.GetPoint("Pick a from point")
If ptRes.Status <> PromptStatus.OK Then Return
fromPt = ptRes.Value
ptRes = editor.GetPoint("Pick a to point")
toPt = ptRes.Value
Dim moveVec As New Vector3d(toPt.X - fromPt.X, toPt.Y - fromPt.Y, toPt.Z - fromPt.Z)
Dim moveMat As Matrix3d = Matrix3d.Displacement(moveVec)
ent.TransformBy(ent.Ecs.PostMultiplyBy(moveMat))
Chris Arps
You are not logged in.
Ask the Community
