.NET
Valued Contributor
yaqiz
Message 1 of 5 (324 Views)
Accepted Solution
Why my document object haven't got CloseAndDiscard or CloseAndSave methods
324 Views, 4 Replies
12-04-2013 07:01 AM
Hi All,
I use AutoCAD 2014, VB.net 2010. I can't see  CloseAndDiscard or CloseAndSave methods under my document object. I would like to close a drawing. What can I do?
Regards
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (201 Views)
Re: Why my document object haven't got CloseAndDiscard or CloseAndSave methods
12-04-2013 09:12 AM in reply to: yaqiz
have you referenced the AcCoreMgd.dll?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Contributor
yaqiz
Message 3 of 5 (199 Views)
12-04-2013 09:21 AM in reply to: Alfred.NESWADBA
Yes.I did I also import
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.Geometry
Valued Mentor
jeff
Message 4 of 5 (190 Views)
12-04-2013 10:41 AM in reply to: yaqiz
Add
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
You can also find your answers @ TheSwamp
mzakiralam
Message 5 of 5 (139 Views)
12-07-2013 10:17 AM in reply to: yaqiz
Below is the code to save or close drawing in ACAD 2014
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
CloseAndDiscard(doc) CloseAndSave(doc, doc.Name)
You are not logged in.
Announcements
Need installation help?
Ask the Community
