.NET
Why my document object haven't got CloseAndDiscard or CloseAndSave methods
4 REPLIES 4
801 Views, 4 Replies
Hi All,
I use AutoCAD 2014, VB.net 2010. I can't see  CloseAndDiscard or CloseAndSave methods under my document object. I would like to close a drawing. What can I do?
Regards
4 REPLIES 4
Alfred.NESWADBA
have you referenced the AcCoreMgd.dll?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Yes.I did I also import
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.Geometry
Add
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
Below is the code to save or close drawing in ACAD 2014
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
CloseAndDiscard(doc) CloseAndSave(doc, doc.Name)
”Boost
