.NET
Why doesn't the menu unload definitively
0 REPLIES 0
Message 1 of 1
195 Views, 0 Replies
I have writen a routine that unloads a menugroup.
Code :
Friend Function UnLoad_Menu(ByVal MenuName As String) As Integer
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Dim curUCS As AcadUCS
Dim ReturnValue As Integer = 0
Try
acadApp = CType(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, AcadApplication)
acadApp.Visible = True
acadDoc = acadApp.ActiveDocument
acadDoc.Application.Visible = True
Dim MenuGroepen As AcadMenuGroups
Dim MenuGroep As AcadMenuGroup
MenuGroepen = acadApp.MenuGroups
'MenuGroepen = acadDoc.Application.MenuGroups
MenuName = Mid(MenuName, InStrRev(MenuName, "\") + 1)
For Each MenuGroep In MenuGroepen
Dim MenuGroepNaam As String = Mid(MenuGroep.MenuFileName, InStrRev(MenuGroep.MenuFileName, "\") + 1)
If MenuGroepNaam.ToUpper = MenuName.ToUpper Then
MenuGroep.Unload()
ReturnValue = 1
End If
Next
acadDoc.Activate()
acadApp.Update()
Return ReturnValue
Catch ex As Exception
MessageBox.Show("Unloading Toolbar" & vbCrLf & ex.ToString)
Return 2
End Try
End Function
If i run the routine it will unload the menugroup, and if you look ik the customize part it isnot there anymore. But when i restart Autocad it does come back until i unload it manualy. What is wrong, I can't find it out.
Can anybody help me. C# is not a problem to me, I can convert it.
With kind regards,
Harold van Aarsen
0 REPLIES 0
”Boost
