.NET
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Why can't create object my code?
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
58 Views, 1 Replies
06-23-2005 07:22 PM
As a beginner,I met a problem,this is my code :
using System ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(ClassLibrary.Class))]
namespace ClassLibrary
/// Summary description for Class.
public class Class
public Class()
// TODO: Add constructor logic here
this.CreateEmployee();
//This function returns the ObjectId for the BlockTableRecord called "EmployeeBlock",
//creating it if necessary. The block contains three entities - circle, text
//and ellipse.
public ObjectId CreateEmployeeDefinition()
ObjectId newBtrId = new ObjectId(); //The return value for this function
Database db = HostApplicationServices.WorkingDatabase; //save some space
Transaction trans = db.TransactionManager.StartTransaction(); //begin the transaction
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.D ocumentManager.MdiActiveDocument.Editor;
try
//Now, drill into the database and obtain a reference to the BlockTable
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
if ((bt.Has("EmployeeBlock")))
newBtrId =bt["EmployeeBlock"];
else
Point3d center = new Point3d(10, 10, 0); // convenient declaration...
// Declare and define the entities we want to add:
//Circle:
Circle circle = new Circle(center, Vector3d.ZAxis, 2);
//Text:
MText text = new MText();
text.Contents = "Earnest Shackleton";
text.Location = center;
//Ellipse:
Ellipse ellipse = new Ellipse(center, Vector3d.ZAxis, new Vector3d(10, 0, 0), 0.5, 0, 0);
//Next, create a layer with the helper function, and assign
//the layer to our entities.
ObjectId empId = CreateLayer();
text.LayerId = empId;
circle.LayerId = empId;
ellipse.LayerId = empId;
//Set the color for each entity irrespective of the layer's color.
text.ColorIndex = 2;
circle.ColorIndex = 1;
ellipse.ColorIndex = 3;
//Create a new block definition called EmployeeBlock
BlockTableRecord newBtr = new BlockTableRecord();
newBtr.Name = "EmployeeBlock";
newBtrId = bt.Add(newBtr); //Add the block, and set the id as the return value of our function
trans.AddNewlyCreatedDBObject(newBtr, true); //Let the transaction know about any object/entity you add to the database!
newBtr.AppendEntity(circle); //Append our entities...
newBtr.AppendEntity(text);
newBtr.AppendEntity(ellipse);
trans.AddNewlyCreatedDBObject(circle, true); //Again, let the transaction know about our newly added entities.
trans.AddNewlyCreatedDBObject(text, true);
trans.AddNewlyCreatedDBObject(ellipse, true);
trans.Commit(); //All done, no errors? Go ahead and commit!
catch
ed.WriteMessage("Error Creating Employee Block");
finally
trans.Dispose();
return newBtrId;
//This function creates a new BlockReference to the "EmployeeBlock" object,
//and adds it to ModelSpace.
[CommandMethod("x")]
public void CreateEmployee()
try
BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForWrite));
BlockTableRecord btr =(BlockTableRecord)trans.GetObject(bt[BlockTableRe cord.ModelSpace], OpenMode.ForWrite);
//Create the block reference...use the return from CreateEmployeeDefinition directly!
BlockReference br = new BlockReference(new Point3d(10, 10, 0), CreateEmployeeDefinition());
btr.AppendEntity(br); //Add the reference to ModelSpace
trans.AddNewlyCreatedDBObject(br, true); //Let the transaction know about it
trans.Commit();
finally
trans.Dispose();
//This function returns the objectId for the "EmployeeLayer", creating it if necessary.
public ObjectId CreateLayer()
ObjectId layerId;
//Get the layer table first...
LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForWrite);
//Check if EmployeeLayer exists...
if (lt.Has("EmployeeLayer"))
layerId = lt["EmployeeLayer"];
else
//If not, create the layer here.
LayerTableRecord ltr = new LayerTableRecord();
ltr.Name = "EmployeeLayer"; // Set the layer name
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, 2);
layerId = lt.Add(ltr);
trans.AddNewlyCreatedDBObject(ltr, true);
trans.Commit();
trans.Dispose();
return layerId;
//can you find any error? why circle and ntext can't create?
using System ;
public class Class
public Class()
//and ellipse.
try
else
//Circle:
//Text:
//Ellipse:
catch
finally
trans.Dispose();
return newBtrId;
try
trans.Commit();
finally
trans.Dispose();
ObjectId layerId;
else
trans.Commit();
trans.Dispose();
return layerId;
Re: Why can't create object my code?
Options
- Highlight
- Email to a Friend
06-23-2005 07:27 PM in reply to:
tr100
sorry,this is my code,
copy error
using System ;
[assembly: CommandClass(typeof(ClassLibrary.okClass))]
namespace ClassLibrary {
/// Summary description for okClass.
public class okClass {
public okClass() {
this.CreateObject();
// Define Command "create"
[CommandMethod("2")]
public void test() { // This method can have any name
// Put your command code here
public ObjectId CreateLayer(){
ObjectId layerid;
Database db=HostApplicationServices.WorkingDatabase;
Transaction trans=db.TransactionManager.StartTransaction();
LayerTable lt=(LayerTable)trans.GetObject(db.LayerTableId,Ope nMode.ForWrite);
if(lt.Has("EmployeeLayer")){
layerid=lt["EmployeeLayer"];
}else{
LayerTableRecord ltr=new LayerTableRecord();
ltr.Name="ne layer!";
layerid=lt.Add(ltr);
trans.AddNewlyCreatedDBObject(ltr,true);
trans.Commit();
trans.Dispose();
return layerid;
public void CreateObject(){
ObjectId newBtrId=new ObjectId();
Editor ed=Autodesk.AutoCAD.ApplicationServices.Applicatio n.DocumentManager.MdiActiveDocument.Editor;
try{
BlockTable bt=(BlockTable)trans.GetObject(db.BlockTableId,Ope nMode.ForWrite);
if(bt.Has("EmployeeBlock")){
newBtrId=bt["my block"];
}else{
ObjectId tempId=this.CreateLayer();
Circle circle=new Circle(new Point3d(10,10,0),Vector3d.ZAxis,50);
circle.LayerId=tempId;
circle.ColorIndex=1;
MText tname=new MText();
tname.Contents="hello!!" ;
tname.LayerId=tempId;
tname.ColorIndex=2;
tname.Location=new Point3d(10,10,0);
BlockTableRecord btr=new BlockTableRecord();
btr.Name="我的block";
newBtrId=bt.Add(btr);
trans.AddNewlyCreatedDBObject(btr,true);
btr.AppendEntity(circle);
btr.AppendEntity(tname);
trans.AddNewlyCreatedDBObject(circle,true);
trans.AddNewlyCreatedDBObject(tname,true);
trans.Commit();
ed.WriteMessage("end!!!");
}catch{
ed.WriteMessage("error!!");
}finally{
trans.Dispose();
using System ;
public okClass() {
ObjectId layerid;
}else{
trans.Commit();
trans.Dispose();
return layerid;
try{
}else{
tname.ColorIndex=2;
btr.Name="我的block";
trans.Commit();
}catch{
}finally{
trans.Dispose();
