.NET
Why can't I make a d*mn line??
2 REPLIES 2
299 Views, 2 Replies
I'm transferring my VBA code to an independent .Net application. I'm working fine with selection sets, layers, even offsets and copy commands - but for some reason, I get an execution error when I try the AddLine method - can someone tell me what's wrong?
Dim testline As AcadLine
Dim testp1(2) As Double
Dim testp2(2) As Double
testp1(0) = 0 : testp1(1) = 0 : testp1(2) = 0
testp2(0) = 5 : testp2(1) = 5 : testp2(2) = 0
Dim oApp As AcadApplication
Dim oDoc As AcadDocument
oApp = GetActiveObject("AutoCAD.Application")
oDoc = oApp.ActiveDocument
testline = oDoc.ModelSpace.AddLine(testp1, testp2)
That's where I get the "System.ExecutionEngineException" error. Help?
2 REPLIES 2
wrote in message news:4958660@discussion.autodesk.com...
Set testline = oDoc.ModelSpace.AddLine(testp1, testp2)
hth
Mark
"MP" wrote in message
news:4966229@discussion.autodesk.com...
oops sorry, just realized this is the dotnet grp.
don't know if syntax is different from vb
hth
Mark
”Boost
