.NET
SRSDS
Message 1 of 3 (208 Views)
When do I need to open a Transaction?
208 Views, 2 Replies
12-14-2011 01:03 PM
I often see examples of accessing objects without opening a transaction.
This has no reference to a transaction
Dim Ent As Entity = ObjID.GetObject(OpenMode.ForRead)
but when I try to use it in a reactor it jumps to the ObjectModified event and then not back to the continuing code.
I have this in my CommandEnded event
           ElseIf e.GlobalCommandName = "EATTEDIT" Then
                'Check if DrawingNo changed
                Dim myXdata As Array = Ent.XData.AsArray
                If myXdata.GetValue(0).value = "TitleBlock" Then
 And don't understand why I need to open a transaction to see if it's a Titleblock
What's the difference between
and
Dim Ent As Entity = trans.GetObject(ObjID, OpenMode.ForRead)
Hope someone can help.
chiefbraincloud
Message 2 of 3 (196 Views)
Re: When do I need to open a Transaction?
12-14-2011 02:12 PM in reply to: SRSDS
and
Short answer, there isn't one.  You must have an active transaction to call GetObject.  Even when you call Objid.GetObject, the Top Level Transaction still handles the object, so if there is no active transaction it will fail.
SRSDS
Message 3 of 3 (158 Views)
12-15-2011 08:49 AM in reply to: chiefbraincloud
Thanks Chief,
 It looks like I'm doing it right then.
