.NET
What tool is use to generate SymbolDataStream
1 REPLY 1
scluna
382 Views, 1 Reply
Hi, May I inquire if anyone here knows how the SymbolDataStream is generated in attached XML file screen shot. Is there a tool which is use to extarct the following SymbolDatastream. I have an image and I want to use it in an xml file but I dont know how to convert it to SymbolDataStream.
Thanks and regards
Note: Below is the SymbolDataStream example i found. I colored with red the one I dont understand how it is generated. is there a tool use to generate this stream?
<PointStyle>
<SymbolName>Stars - Black</SymbolName>
<SymbolWidth>0.002</SymbolWidth>
<SymbolHeight>0.002</SymbolHeight>
<SymbolRotation>0</SymbolRotation>
<MaintainAspectRatio>1</MaintainAspectRatio>
<SymbolStyleOverrides>
<TextColorIndex>1</TextColorIndex>
<LineColorIndex>1</LineColorIndex>
<FillColorIndex>1</FillColorIndex>
<EdgeColorIndex>1</EdgeColorIndex>
</SymbolStyleOverrides>
<SymbolDataStream>
002100001022000110A60000000900171102001011227FFF11660001FFFF000111
E2FFFE006E0D5374617273202D20426C61636B202600013BFE01FC304600000009
0017008053843F51DEDC53C2000152C2000140FF002C1B4608A63F56228F637008
A6559433277A364DDB4D314DDB3F56789431854DDB04474DDB292233271B4608A6
00A00040
</SymbolDataStream>
</PointStyle>
SCLuna
1 REPLY 1
scluna
in reply to: scluna
Accidentally I found how to get the definition simply by using a notepad in opening an mwx file
SCLuna
”Boost
