.NET
What is the difference between .Net created and Interop object created layer?
3 REPLIES 3
yaqiz
803 Views, 3 Replies
Hi Guys,
I have used VB.net created a layer. then place a polyline on this layer. Then I use Teigh object export the drawing to bmp
oHost =
New TeighaX.OdaHostApp 'Create the DDX application
oBmp =
New TeighaX.OdaBmpOut 'Create the bmp-exporter'Variable stores a reference to the current drawing
oDoc = oHost.Application.Documents.Open(strDrawingPath)
'Open a drawing from the specified dwg-file
oBmp.WriteFile(oDoc.Database, strThumbBMPPath)
This throw an error.
However if I use COM Interop Object create a layer. place the same polyline on it. Then use the same code to export drawing to bmp. There is no error.
I think there must be different between .Net created layer to COM Interop created layer. Could anybody give me a hint? This drive me mad now.
here are code
VB.Net
    Public Function AutoCADCreateLayer(ByVal strLayerName As String, Optional ByVal lngLayerColour As Long = -1, _
                                       Optional ByVal blnLayerOn As Boolean = True, Optional ByVal blnLayerLocked As Boolean = False) As Boolean
        Dim db As Database = acApp.DocumentManager.MdiActiveDocument.Database
        Dim blnRt As Boolean
        Try
            Using lock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
                Using trans As Transaction = db.TransactionManager.StartTransaction
                    Dim objLayertb As LayerTable = db.LayerTableId.GetObject(OpenMode.ForWrite)
                    Dim objNewLayer As New LayerTableRecord
                    With objNewLayer
                        .Name = strLayerName
                        .Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, lngLayerColour)
                        '    .IsHidden = Not blnLayerOn
                        '   .IsLocked = blnLayerLocked
                    End With
                    objLayertb.UpgradeOpen()
                    Dim objNewLayerID As ObjectId = objLayertb.Add(objNewLayer)
                    trans.AddNewlyCreatedDBObject(objNewLayer, True)
                    db.Clayer = objNewLayerID
                    trans.Commit()
                End Using
                blnRt = True
            End Using
        Catch ex As Exception
            acApp.ShowAlertDialog("Error in create layer: " & ex.Message)
            Debug.Assert(False)
            blnRt = False
        Catch ex As SystemException
            acApp.ShowAlertDialog("Erro in create layer: " & ex.Message)
            Debug.Assert(False)
            blnRt = False
        End Try
        Return blnRt
    End Function
 COM Interop
Dim objCOMDrawing As Autodesk.AutoCAD.Interop.AcadDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
objCOMDrawing.Layers.Add("mylayername")
Thanks very much
3 REPLIES 3
Hallex
in reply to: yaqiz
If you're adding layer in the current document
me think you need to remove" using LockDocument.. " code block from there,
just a guess, sorry
DiningPhilosopher
in reply to: yaqiz
Are you sure you're asking your question in the right place ?
There's plenty of implementation differences between AutoCAD and other look-a-like APIs, and I don't know if this is the best place to ask about them.
What type of error is shown? If it is in one of your catch statements what does ex.message say?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
”Boost
