.NET
We're trying to convert VB to VB.Net
8 REPLIES 8
Message 1 of 9
932 Views, 8 Replies
We're trying to convert VB to VB.Net and need some pointers to get it up and running. We need to go through all blocks and search for an attribute called "REV" in a .dwg drawing. We then need to read the value into the "Revision" variable.
'' Get revision character
                        Dim blk As Object
                        Dim varAttributes As Object
                        Dim blockrefobj As AcadBlockReference  <- Not defined
                        Dim i As Integer
                        Dim Revision As String
                        Dim AcadApp As Application
                        AcadApp = GetObject(, "AutoCAD.Application.17")
                        Dim thisDrawing As Object = Application.DocumentManager.MdiActiveDocument.AcadDocument()
                        For Each blk In thisDrawing.Modelspace()
                            If blk.EntityName = "AcDbBlockReference" Then
                                blockrefobj = blk
                                If blockrefobj.HasAttributes Then
                                    varAttributes = blockrefobj.GetAttributes
                                    For i = LBound(varAttributes) To UBound(varAttributes)
                                        If varAttributes(i).TagString = "REV" Then
                                            Revision = varAttributes(i).TextString
                                    Next i
                        Next
Do someone have some tips that could help us in the right direction?
Thanks in advance!
Best regards
B&A
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
find the code for doing your job, not built for COM-handling. Using transactions makes it much faster!
'On Top of your Class/Module you have to set:
Import Autodesk.AutoCAD
      Public Sub RevisionChange(ByVal RevStr As String)
         Dim tAcadDoc As ApplicationServices.Document = Nothing
         Dim tAcadDocLock As ApplicationServices.DocumentLock = Nothing
         Dim tTrAct As DatabaseServices.Transaction = Nothing
         Try
            tAcadDoc = ApplicationServices.Application.DocumentManager.MdiActiveDocument
            tAcadDocLock = tAcadDoc.LockDocument
            tTrAct = tAcadDoc.TransactionManager.StartTransaction
            Dim tBlTab As DatabaseServices.BlockTable = CType(tTrAct.GetObject(tAcadDoc.Database.BlockTableId, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTable)
            Dim tModelSpace As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tBlTab("MODEL_SPACE"), DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord)
            For Each tDbObjID As DatabaseServices.ObjectId In tModelSpace
               If (tDbObjID.IsValid) AndAlso (Not tDbObjID.IsErased) AndAlso (tDbObjID.ObjectClass.DxfName = "INSERT") Then
                  'ok, now we know that we have the objectid of a blockreference
                  Dim tBlRef As DatabaseServices.BlockReference = CType(tTrAct.GetObject(tDbObjID, DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockReference)
                  If (tBlRef.AttributeCollection IsNot Nothing) AndAlso (tBlRef.AttributeCollection.Count > 0) Then
                     'now we know, this BlockReference has attributes, let's scan through them
                     For Each tAttRefID As DatabaseServices.ObjectId In tBlRef.AttributeCollection
                        If (tAttRefID.IsValid) AndAlso (Not tAttRefID.IsErased) Then
                           Dim tAttRef As DatabaseServices.AttributeReference = CType(tTrAct.GetObject(tAttRefID, DatabaseServices.OpenMode.ForRead), DatabaseServices.AttributeReference)
                           If tAttRef.Tag.ToUpper = "REV" Then
                              tAttRef.TextString = RevStr
                              Exit For 'we need not scan through more attributes as we found "REV" in the collection of this BlockReference
                     Next
            Next
            tTrAct.Commit()
         Catch ex As Exception
            Call MsgBox("Error executing 'RevisionChange'" & vbNewLine & ex.Message)
         Finally
            If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
            If tAcadDocLock IsNot Nothing Then tAcadDocLock.Dispose() : tAcadDocLock = Nothing
         End Try
      End Sub
Just wrote, not verified, so be careful running this on drawings without saving before 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
sorry, 2 mistakes:
1) in the first line: Imports Autodesk.AutoCAD 'here one "s" was missing
2) and before setting the TextString of the AttributeReference, it has to be opened ForWrite ... and not ForRead!
Sorry, -alfred -
Alfred NESWADBA
Message 4 of 9
in reply to: Alfred.NESWADBA
Thank you for a quick response. We just want to read the attribute not change it. So the 2. point you raise seems to be correct already. However we get this error when running the code: "Error executing 'RevisionChange' eKeyNotFound".
Best regards
B&A
Message 5 of 9
Alfred.NESWADBA
lost a star in this (now corrected) line:
Dim tModelSpace As DatabaseServices.BlockTableRecord = CType(tTrAct.GetObject(tBlTab("*MODEL_SPACE"), DatabaseServices.OpenMode.ForRead), DatabaseServices.BlockTableRecord)
 >> We just want to read the attribute not change it
In this case I don't understand, why you scan through the complete model-space. If you look for a title-block to get the revision it would be much faster to do a select and not to go through maybe thousands of entities.
- alfred -
Alfred NESWADBA
Message 6 of 9
That worked perfect! Thank you very much, you made our day!
Best Regards
B&A
Message 7 of 9
arcticad
You can also get Modelspace like this
    Function getModelSpace(ByRef tr As Transaction, ByRef db As Database) As BlockTableRecord
        Dim rtnBTR As BlockTableRecord = Nothing
        Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
        For Each btrId As ObjectId In bt
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(btrId, OpenMode.ForRead), BlockTableRecord)
            If btr.IsLayout AndAlso btr.Name.ToUpper() = BlockTableRecord.ModelSpace.ToUpper() Then
                rtnBTR = btr
                Exit For
        Next
        Return rtnBTR
    End Function
(defun botsbuildbots() (botsbuildbots))
Message 8 of 9
chiefbraincloud
in reply to: arcticad
You could, but I wouldn't...
Most times I get the model (or paper) space by the OwnerId of an object I have selected.  This example would have to select the block first using a filter (like alfred already suggested).
If I must open ModelSpace without having a preselected child, then I use
SymbolUtilityServices.GetBlockModelSpaceId ( db as Database) As ObjectId
to get the ObjectId.  As you can see from the signature, it has the added benefit of a Database argument, so it even works when you are working with a side database, like when you use ReadDwgFile.
Message 9 of 9
arcticad
in reply to: chiefbraincloud
chiefbraincloud,
You win the shortest code contest.
”Boost
