• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    WblockCloneObjects Layout of Inventor DWG
    105 Views, 0 Replies
    01-19-2012 05:58 AM
    I'm trying to WblockCloneObjects an Inventor2012 dwg in Autocad 2012.
    In this file there is just 1 layout called "Blad"
    I get the objectIDs (23 in my case) but I can't see them in Autocad displayed.
    I only see the new Layout!
    My routine works well for WblockCloneObjects Autocad2012 dwg!
    What am I missing? or isn't this possible at all because its an Inventor dwg?
    Geert
    Code:
     public static Database WblockCloneFromExternalDWGfile(string filename, bool isinventorfile)
             Database targetDatabase = Active.WorkingDatabase;
             Database sourchDatabase = new Database(false, true);
             sourchDatabase.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, true, "");
             targetDatabase.Dimscale = sourchDatabase.Dimscale;
            using (Transaction sourchTransaction = sourchDatabase.TransactionManager.StartTransaction())
                 BlockTable sourchBlockTable = (BlockTable)sourchDatabase.BlockTableId.GetObject(OpenMode.ForRead);
                 BlockTableRecord sourchSpace;
                 if (isinventorfile) { sourchSpace = (BlockTableRecord)sourchBlockTable
        [BlockTableRecord.PaperSpace].GetObject(OpenMode.ForRead); }
                else { sourchSpace = (BlockTableRecord)sourchBlockTable[BlockTableRecord.ModelSpace].GetObject
                ObjectIdCollection objectIDCollection = new ObjectIdCollection();
                foreach (ObjectId objectID in sourchSpace) { objectIDCollection.Add(objectID); }
                using (Transaction targetTransaction = targetDatabase.TransactionManager.StartTransaction())
                    BlockTable targetBlockTable = (BlockTable)targetDatabase.BlockTableId.GetObject(OpenMode.ForRead);                 BlockTableRecord targetSpace;
                     if (isinventorfile)
                         ObjectId newLayoutId = LayoutManager.Current.CreateLayout("Blad");
                         Layout newLayout = (Layout)newLayoutId.GetObject(OpenMode.ForWrite);
                         LayoutManager.Current.CurrentLayout = newLayout.LayoutName;
                         //targetSpace = (BlockTableRecord)targetBlockTable[BlockTableRecord.PaperSpace].GetObject
                         targetDatabase.WblockCloneObjects(objectIDCollection, newLayout.BlockTableRecordId, new IdMapping(),
        DuplicateRecordCloning.Replace, false);
                     else  //Autocad DWG
                         targetSpace = (BlockTableRecord)targetBlockTable[BlockTableRecord.ModelSpace].GetObject
                         targetDatabase.WblockCloneObjects(objectIDCollection, targetSpace.ObjectId, new IdMapping(),
                    targetTransaction.Commit();
             return targetDatabase;
    Please use plain text.
