.NET
-WBlock produces different results than WBlock when in UCS.
0 REPLIES 0
Message 1 of 1
adam
300 Views, 0 Replies
New issue in 2013
Steps to Reproduce
Draw a Line
UCS Object - Choose Object
-WBlock out (ie command line version)
XRef in - appears in different place.
Repeat experiment with regular WBlock command lien appear in the correct place - ie where it was before we WBlocked it.
Appears that INSBASE is incorrectly set in the new dwg with -WBlock.
Note using Map 2013 so not sure if that is an issue.
Anyone programatically using the command line version of WBlock shouid be aware of this
Adam
0 REPLIES 0
”Boost
