.NET
Visual studio and visual basic get properties
3 REPLIES 3
matrax1405
566 Views, 3 Replies
Hi could help me with this exercise please, but I want to do a Windows Form in visual studio then connect AutoCAD using VISUAL BASIC and when clicking to give the line attributes display in a tectbox or label.you could help me please
Tags (2)
3 REPLIES 3
dgorsman
in reply to: matrax1405
Usually its best to start at the start: define the problem.
- what types of objects are being worked with?  Lines and circles?  Text?  Vertical content?  Third-party objects?
- what information is available?  Can it be read from an object, or does it have to come from the user, or from a data source?
- what do you want to do with them?  What would it look like?
- what type of user input is required?
Once the problem is defined, then you can start getting into detail about the "how".
- what do you know?
- What do you NOT know, and need to figure out?
Once you've got an idea of what you do (and more imporantly DON'T) know, you can peel back the layers of work.  Build in logical steps so each can be tested before going on to the next.  Sometimes you end up hitting a wall you can't get around, and have to back up and redo work.  Sometimes you have to do more research to see if what you are trying to do is appropriate, effective, and/or reasonable.
Finally, you end up at the end: with working code.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
matrax1405
in reply to: dgorsman
Hi first of all thank you very much for answering looks attached a video that I found just what I do not found the solution I hope I can help.
The video shows how to get the length of a line and a polyline by selecting it, and apart to get the value but touching 2 point line in the plane.
I have to do this in visual basic creating a form with visual studio 2012 and AutoCAD 2014
really really appreciate it if you can help me. Man Sad
mzakiralam
Hi ,
Please try below code for your problem. To invoke the winform, code is below:
 <CommandMethod("tst")> Public Sub TestForm()
        Dim frm As TESTFORM = New TESTFORM()
        Application.ShowModelessDialog(Application.MainWindow.Handle, frm, False)
    End Sub
to get properties and place text code is below:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class TESTFORM
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        'to get properties
        Me.Hide()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf & "Select line or polyline: ")
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Return
        Using docLock As DocumentLock = doc.LockDocument
            Using tx As Transaction = db.TransactionManager.StartTransaction()
                Dim ent As Entity = tx.GetObject(per.ObjectId, OpenMode.ForRead)
                If TypeOf ent Is Line Then
                    Dim ln As Line = TryCast(ent, Line)
                    TextBox1.Text = TextBox1.Text & "Line Length: " & ln.Length & vbNewLine
                ElseIf TypeOf ent Is Polyline Then
                    Dim pl As Polyline = TryCast(ent, Polyline)
                    TextBox1.Text = TextBox1.Text & "Polyline Length: " & pl.Length & vbNewLine
                tx.Commit()
            End Using
        End Using
        Me.Show()
    End Sub
    Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click
        'to place text
        Me.Hide()
        Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "Select a point to place text: ")
        Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim btr As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Dim mtxt As MText = New MText()
                mtxt.Location = ppr.Value
                mtxt.Attachment = AttachmentPoint.MiddleCenter
                mtxt.TextHeight = 1.5
                mtxt.Contents = TextBox1.Text
                mtxt.ColorIndex = 256
                btr.AppendEntity(mtxt)
                tx.AddNewlyCreatedDBObject(mtxt, True)
                tx.Commit()
            End Using
        End Using
        Me.Show()
    End Sub
End Class
”Boost
