Visual Studio Express 2010
I have upgrated from Visual Studio Express 2008 to Express 2010. After this update I can't debug my dll.
Usually I follow this:
1) from VS launch debug (F5)
2) from Autocad load the dll with NETLOAD and run command
At this point if I set breakpoint, the debug don't pause to this line.
Any idea? with Express 2008 all work fine
Stefano
chiefbraincloud
This post on Through the Interface should help.
http://through-the-interface.typepad.com/through_the_interface/2010/04/hitting-breakpoints-in-net-cl...
Thnathank you,  I have try this solution but don't work....
Are you loading the release version instead of the debug version?
Hi
I have the same issue: breakpoints don't work when debugging in VS 2010. I have my framework set on 3.5 (otherwise it wouldn't work with ACAD 2011 at all).
I also read the article at http://through-the-interface.typepad.com/through_the_interface/2010/04/hitting-breakpoints-in-net-cl...
but those solutions don't work for me.
Have you ever solved this problem, scarta? ...or can anybody else give an advice in this regard?
Thanx,
Matej
I also have no working solution, its soooo fustraiting,
Need an update to MS VS 2010.
In order to have AutoCAD started from within Visual Studio 2008 i had to add these lines:
        ..\Visual Studio 2008\Projects\ClassLibrary2\ClassLibrary2\ClassLibrary2.vbproj.user
        Add:
        <Project xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
          <PropertyGroup>
            <ProjectView>ShowAllFiles</ProjectView>
          </PropertyGroup>
          <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
            <StartAction>Program</StartAction>
            <StartProgram>C:\Program Files\AutoCAD ...\acad.exe</StartProgram>
            <StartWorkingDirectory>C:\Program Files\AutoCAD ...\</StartWorkingDirectory>
          </PropertyGroup>
          <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
          </PropertyGroup>
        </Project>
I do not have the express version of 10 anymore so i cannot test this for you.
