• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *AlmightySR
    Visual Studio 2005 Beta
    76 Views, 21 Replies
    05-18-2005 04:30 AM
    Thank god there is a dot net one now... Thank you Autodesk.
    Anyone get Visual Studio 2005? Impressions?
    Please use plain text.
    *Jaime
    Re: Visual Studio 2005 Beta
    05-18-2005 05:27 AM in reply to: *AlmightySR
    I'm still waiting for my beta copy to show up. Over the last month I have
    been attempting the transistion from VB6 to .net.
    Distinguished Contributor
    05-18-2005 05:51 AM in reply to: *AlmightySR
    Depending upon you application, it works just fine for me.
    *LFA Laurent
    05-18-2005 06:50 AM in reply to: *AlmightySR
    Visual Studio 2005 Beta or Sharpdevelopp, no crash with autocad for the
    moment.
    it' s will be good
    Laurent Falla
    LFA Consulting Limited (Civil Design & development)
    www.lfaconsulting.com
    "AlmightySR" a écrit dans le message de news:
    4848629@discussion.autodesk.com...
    *Mike Tuersley
    05-18-2005 07:13 AM in reply to: *AlmightySR
    Apps done in Visual Studio 2005 that interface with
    Autodesk.AutoCAD.Runtime.IExtensionApplication will crash with AutoCAD
    2006+. If you limit your code to interaction with graphics, it should be
    okay. If you start getting odd errors with cad, back down to 2003
    -- Mike
    ___________________________
    Mike Tuersley
    the trick is to realize that there is no spoon...
    05-18-2005 07:18 AM in reply to: *AlmightySR
    The Version of #develop i have does not work with the managed wrapper classes of Autocad.
    Visual C# Express Beta does work without any problems.
    Roland
    05-18-2005 08:59 AM in reply to: *AlmightySR
    Be sure to edit the acad.exe.config file to use the recommended version of dotnet. The default is to use the latest version and VS2005 will cause problems with 2006 based Autodesk based products.
    I have heard of one person who could not run the layer command in 2006 (it is now a dot net ui) after installing VS2005. Editing acad.exe.config fixed the problem.
    *Albert Szilvasy
    05-18-2005 11:09 AM in reply to: *AlmightySR
    Hi Mike,
    What error are you seeing? I have test apps here that use this interface and
    they work fine even when I compile them with VS2005 Beta2.
    Albert
    "Mike Tuersley" wrote in message
    news:4848908@discussion.autodesk.com...
    -- Mike
    Mike Tuersley
    *Albert Szilvasy
    05-18-2005 11:16 AM in reply to: *AlmightySR
    .NET 2.0 Beta2 is very close to being compatible with AutoCAD 2006 (previous
    betas and CTP build had a lot more compatibility issues). If you develop
    .net applications using VS2005 you *must* run AutoCAD on .NET 2.0 Beta2.
    The only problem I'm aware of at this point is an annoying error dialog that
    comes up when you run the layer command. The layer dialog will come up after
    you hit Ok to the error dialog. This is a bug in .NET 2.0 Beta2 that MS has
    already fixed in their internal builds according to their bug tracking
    system:
    http://lab.msdn.microsoft.com/productfeedback/viewfeedback.aspx?feedbackid=cfe99155-48bc-4180-adbc-81c33212cc12
    Please let me know if you experience any other issues running AutoCAD on
    .NET 2.0 Beta2.
    Albert
    wrote in message news:4849146@discussion.autodesk.com...
    the problem.
    *Ed Jobe
    05-18-2005 11:28 AM in reply to: *AlmightySR
    Albert, just for clarification purposes, do you mean the framework when you
    say ".Net 2.0 beta 2"?
    Ed
    "Albert Szilvasy" wrote in message
    news:4849409@discussion.autodesk.com...
    system:
    .NET 2.0 Beta2.
    Albert
    the problem.
