.NET
Visual Studio 2005 Beta
21 REPLIES 21
Message 1 of 22
1152 Views, 21 Replies
Thank god there is a dot net one now... Thank you Autodesk.
Anyone get Visual Studio 2005? Impressions?
21 REPLIES 21
Message 2 of 22
I'm still waiting for my beta copy to show up. Over the last month I have
been attempting the transistion from VB6 to .net.
Message 3 of 22
Mikko
Depending upon you application, it works just fine for me.
Message 4 of 22
Visual Studio 2005 Beta or Sharpdevelopp, no crash with autocad for the
moment.
it' s will be good
Laurent Falla
LFA Consulting Limited (Civil Design & development)
www.lfaconsulting.com
"AlmightySR" a écrit dans le message de news:
4848629@discussion.autodesk.com...
Message 5 of 22
Apps done in Visual Studio 2005 that interface with
Autodesk.AutoCAD.Runtime.IExtensionApplication will crash with AutoCAD
2006+. If you limit your code to interaction with graphics, it should be
okay. If you start getting odd errors with cad, back down to 2003
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Message 6 of 22
The Version of #develop i have does not work with the managed wrapper classes of Autocad.
Visual C# Express Beta does work without any problems.
Roland
Message 7 of 22
ChrisArps
Be sure to edit the acad.exe.config file to use the recommended version of dotnet. The default is to use the latest version and VS2005 will cause problems with 2006 based Autodesk based products.
I have heard of one person who could not run the layer command in 2006 (it is now a dot net ui) after installing VS2005. Editing acad.exe.config fixed the problem.
Message 8 of 22
Hi Mike,
What error are you seeing? I have test apps here that use this interface and
they work fine even when I compile them with VS2005 Beta2.
Albert
"Mike Tuersley" wrote in message
news:4848908@discussion.autodesk.com...
-- Mike
Mike Tuersley
Message 9 of 22
.NET 2.0 Beta2 is very close to being compatible with AutoCAD 2006 (previous
betas and CTP build had a lot more compatibility issues). If you develop
.net applications using VS2005 you *must* run AutoCAD on .NET 2.0 Beta2.
The only problem I'm aware of at this point is an annoying error dialog that
comes up when you run the layer command. The layer dialog will come up after
you hit Ok to the error dialog. This is a bug in .NET 2.0 Beta2 that MS has
already fixed in their internal builds according to their bug tracking
system:
http://lab.msdn.microsoft.com/productfeedback/viewfeedback.aspx?feedbackid=cfe99155-48bc-4180-adbc-81c33212cc12
Please let me know if you experience any other issues running AutoCAD on
.NET 2.0 Beta2.
Albert
wrote in message news:4849146@discussion.autodesk.com...
the problem.
Message 10 of 22
Albert, just for clarification purposes, do you mean the framework when you
say ".Net 2.0 beta 2"?
Ed
"Albert Szilvasy" wrote in message
news:4849409@discussion.autodesk.com...
system:
.NET 2.0 Beta2.
Albert
the problem.
Message 11 of 22
Yes. I mean the basic runtime. You can get this in 3 ways:
1. You download the .NET 2.0 Beta2 redistributable.
http://lab.msdn.microsoft.com/vs2005/downloads/netframework/default.aspx
2. You download the .NET 2.0 Beta2 SDK.
3. You download one of the VS2005 flavors.
Albert
"Ed Jobe" wrote in message
news:4849429@discussion.autodesk.com...
Ed
system:
.NET 2.0 Beta2.
Albert
the problem.
Message 12 of 22
thx
Ed
news:4849454@discussion.autodesk.com...
Albert
Ed
system:
.NET 2.0 Beta2.
Albert
the problem.
Message 13 of 22
Use the tab extension to add a tab to the Options dialog box. Then the
following things happen:
- going into layer manager and it pops a fatal error
- leave AutoCAD and random message appear from acmgd.arx [I believe]
- trying to use a browse for folder dialog in the tab will not bring the
folder dialog to the top so acad hangs
-- Mike
Mike Tuersley
Message 14 of 22
Ewhhh...seems you got the layer mgr issue resolved in your other post.
Kudos Albert!
-- Mike
Mike Tuersley
Message 15 of 22
>> will not bring the folder dialog to the top so acad hangs
That shouldn't happen. Can you post the code?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Message 16 of 22
Ok, this one was done in VB.NET. Just start a new controls project and have
a class and a user control. The code for the class is below. For the
usercontrol, just add a textbox, a button, and a FolderBrowserDialog
control. The pertinent code here is for the button:
Private Sub BrowseButtons_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles btnBrowse1.Click, btnBrowse2.Click
'System.Windows.Forms.MessageBox.Show("?")
Me.FolderBrowserDialog1.Description = "Select the folder..."
If Me.FolderBrowserDialog1.ShowDialog(Me.ParentForm) = DialogResult.OK
Then
Select Case sender.name.toupper
Case Is = "BTNBROWSE1" 'browse for drawings
Me.txtDwgPath.Text = Me.FolderBrowserDialog1.SelectedPath
Case Is = "BTNBROWSE2" 'browse for blocks
Me.txtBlkPath.Text = Me.FolderBrowserDialog1.SelectedPath
End Select
End If
End Sub
For the FolderBrowserDialog to "show" all you should need is a call to ME
...ShowDialog(Me) or ShowDialog(Me.ParentForm). This works fine if you
restrict 2006 to using 1.1.4322. If you remove this restriction from the
acad.exe.config file and run with 2.0, the same code fails to display the
FolderBrowserDialog.
CLASS CODE:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Public Class OGIDefaults
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Private Shared myCtrl As TabExtension
Public Sub Initialize() Implements
Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
'fire up the toolpalette set
Try
'Enable XP
System.Windows.Forms.Application.EnableVisualStyles()
StartInterface()
Catch ex As System.Exception
Console.WriteLine(ex)
End Try
End Sub
Public Sub Terminate() Implements
Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
'handle user closing toolpalette set
myCtrl.Dispose()
End Sub
_
Public Shared Sub StartInterface()
AddHandler
Autodesk.AutoCAD.ApplicationServices.Application.DisplayingOptionDialog,
AddressOf Application_TabbedDialog
AddHandler
Autodesk.AutoCAD.ApplicationServices.Application.DisplayingDraftingSettingsDialog,
AddHandler
Autodesk.AutoCAD.ApplicationServices.Application.DisplayingCustomizeDialog,
End Sub
Private Shared Sub Application_TabbedDialog(ByVal sender As Object, ByVal
e As Autodesk.AutoCAD.ApplicationServices.TabbedDialogEventArgs)
myCtrl = New TabExtension
e.AddTab("Ohio Gratings", New
Autodesk.AutoCAD.ApplicationServices.TabbedDialogExtension(myCtrl, _
New Autodesk.AutoCAD.ApplicationServices.TabbedDialogAction(AddressOf
myCtrl.OnOk), _
myCtrl.OnCancel), _
myCtrl.OnHelp) _
) _
End Sub
End Class
-- Mike
Mike Tuersley
Message 17 of 22
Oh! Also implementing this with 2.0 causes the error when trying to run
layer manager which Albert already got MS to fix.
-- Mike
Mike Tuersley
Message 18 of 22
This is a bug in AutoCAD. Add the following code to your user control to
workaround the problem. (Sorry about providing it in C#. My eyes are more
accustomed to this C-ish syntax.)
const int GWL_EXSTYLE = -20;
const int WS_EX_CONTROLPARENT = 0x00010000;
[DllImport("user32.dll")]
private static extern int SetWindowLong(IntPtr hWnd, int nIndex, int
dwNewLong);
private static extern int GetWindowLong(IntPtr hWnd, int nIndex);
private static extern IntPtr GetParent(IntPtr hWnd);
protected override void OnLoad(EventArgs e)
//workaround bug in AutoCAD: the WS_EX_CONTROLPARENT style is
not set on the tab hosting
//our user control (the parent of the our control). This
confuses user32.dll into hanging in
//an infinite loop. Manually set the style to correct this.
IntPtr hwndParent = GetParent(this.Handle);
SetWindowLong(hwndParent,GWL_EXSTYLE,GetWindowLong(hwndParent,GWL_EXSTYLE)
| WS_EX_CONTROLPARENT);
base.OnLoad (e);
Albert
news:4851606@discussion.autodesk.com...
Then
End Select
End If
End Sub
CLASS CODE:
Try
'Enable XP
StartInterface()
End Try
End Sub
myCtrl.Dispose()
End Sub
_
AddHandler
AddHandler
AddHandler
End Sub
myCtrl.OnOk), _
myCtrl.OnCancel), _
myCtrl.OnHelp) _
) _
End Sub
End Class
-- Mike
Mike Tuersley
Message 19 of 22
Thanks, Albert! I can handle either language
-- Mike
Mike Tuersley
Message 20 of 22
I know this thread is dead(ish) But thanks for posting this morsel.
After installing VS C# beta 2 the layer manger was borked. the
acad.exe.config edit (uncommenting the line) fixed it up nicely.
David Kurtz
Peckham & Wright Architects, Inc.
Columbia, Missouri
”Boost
