.NET
Active Member
Danny.isr
Message 1 of 1 (171 Views)
Viewport.ViewCenter doesn't seem to work ok if Viewport.TwistAngle is not 0
171 Views, 0 Replies
12-03-2008 02:59 AM
what not right
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Test
_
Public Sub Test()
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim ed As Autodesk.AutoCAD.EditorInput.Editor
ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
Dim trans As Autodesk.AutoCAD.DatabaseServices.Transaction = tm.StartTransaction
Try
Dim lid As ObjectId
Dim LayoutDictionary As DBDictionary = tm.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, False)
If LayoutDictionary.Contains("1") Then
lid = LayoutDictionary.Item("1")
Else
lid = LayoutManager.Current.CreateLayout("1")
End If
LayoutManager.Current.CurrentLayout = "1"
Dim Layout As Layout = tm.GetObject(lid, OpenMode.ForWrite, False)
Dim Viewport As Viewport = tm.GetObject(Layout.GetViewports(1), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False)
Viewport.Locked = False
Viewport.TwistAngle = -0.89382539718635012
Viewport.Width = 500
Viewport.Height = 300.0
Viewport.CenterPoint = New Point3d(13, 25, 0)
Viewport.ViewCenter = New Point2d(500, 400) ' not 500,400 bat ViewCenter =X= 1.4576 Y= 640.0352
Viewport.CustomScale = 2
Viewport.Locked = True
Viewport.On = True
trans.Commit()
Catch e As System.Exception
ed.WriteMessage(e.Message)
trans.Abort()
Finally
trans.Dispose()
End Try
End Sub
End Class
You are not logged in.
Ask the Community
