.NET
VSE 2013 debugger
5 REPLIES 5
mfernandes
450 Views, 5 Replies
VSE 2013 debugger
Any have success using visual  studio 2013 vb.net and AutoCAD 2014 win7/64
I get the following when I select the start debugging.
"In order to debug this project, add an executable project to this solution which references the library project. Set the executable project as the startup project."
5 REPLIES 5
hgasty1001
in reply to: mfernandes
Not sure as i don`t use VSE, but I think that message refers to add the Autocad executable to the project, and set that exe as startup project, see this link third method:Debuggin
Gaston Nunez
mfernandes
in reply to: hgasty1001
thanks Gaston Nunez
mfernandes
any idea why when I select , Debug, Start command
my dll is not rebuild with the changes.
I am sure in VBE 2010 it built my dll via the debug command and I simpley had to netload in AutoCAD
I cannot find where I need to set this in VSE2013
hgasty1001
I don't know if this work in Express, but in VS you have to go to Tools Menu->Options->Projects and Solutions->Build and Run and set your preferences there.
Gaston Nunez
mfernandes
this is what I have for settings and it would seem that my dll should be build and saved in the bin\Debug\ folder.
But the only time this happens is if I select the build command.
OK I just figured it out.
Seem you have to uncheck the "Only build startup projects and dependencies on Run"
is this correct?
”Boost
