.NET
Distinguished Contributor
SRSDS
Message 1 of 3 (354 Views)
VS2010 & AutoCAD 2009 Netload problem
354 Views, 2 Replies
07-12-2012 04:00 AM
I have created a program with VS2010 with a target .NET4.0.
It works fine in later versions of AutoCAD but I’m trying to get it to work under 2009 (Windows 7).
I get an error when trying to NETLOAD the .dll saying :
Cannot load assembly. Error details: System.BadImageFormatException:
This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded.
I’ve tried adding v4.0 to acad.exe.config as suggested but then I get a fatal error when AutoCAD loads.
<configuration>
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v4.0"/>
  </startup>
<!--All assemblies in AutoCAD are fully trusted so there's no point generating publisher evidence-->
   <runtime>
        <generatePublisherEvidence enabled="false"/>
   </runtime>
</configuration>
Active Member
olivier.eckmann
Message 2 of 3 (349 Views)
Re: VS2010 & AutoCAD 2009 Netload problem
07-12-2012 04:52 AM in reply to: SRSDS
AutoCAD 2009 uses framework 3.0, so you need to target Framework 3 instead of framework 4.
Olivier
khoa.ho
Message 3 of 3 (298 Views)
08-03-2012 07:24 PM in reply to: SRSDS
On AutoCAD installation folder, look for acad.exe.config, enable supportedRuntime to allow Visual Studio 2010 debugging .NET framework 2.0 and 3.5 on AutoCAD. VS2010 by default uses .NET framework 4.0 to debug.
<configuration>
<startup>
<supportedRuntime version=”v2.0.50727″/>
</startup>
</configuration>
On Visual Studio 2010, go to Project Properties (right-click on project name and select Properties), then select Application tab, select Target framework 3.0 for AutoCAD 2009 or 3.5 for AutoCAD 2011.
-Khoa
You are not logged in.
Ask the Community
