.NET
VS2002 Internal Compiler Error with ResultBufferEnumerator ???
8 REPLIES 8
Message 1 of 9
548 Views, 8 Replies
I'm getting the output shown below, which appears to be
caused by this:
Object o = //
if( o is ResultBuffer )
ResultBuffer buf = (ResultBuffer) o;
/// iterating the ResultBuffer contents is
/// causing the error. commenting out this
/// foreach construct makes it go away:
foreach( TypedValue val in buf )
// Do something with val
Here is the compiler output copied from the output window:
error CS0583: Internal Compiler Error (0xc0000005 at address 531A15B7): likely culprit is 'BIND'.
An internal error has occurred in the compiler. To work around this problem, try simplifying or changing the program
near the locations listed below. Locations at the top of the list are closer to the point at which the internal error
occurred.
C:\Projects\test\bin\Debug\acdbmgd.dll: error CS0584: Internal Compiler Error: stage 'BIND' symbol
'Autodesk.AutoCAD.DatabaseServices.ResultBufferEnumerator.Current'
c:\Projects\test\rxadsdotnet.cs(601,19): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(597,16): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(596,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(590,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(576,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(570,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(561,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(546,21): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(540,16): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(539,13): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(538,13): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(536,10): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(535,10): error CS0585: Internal Compiler Error: stage 'BIND'
c:\Projects\test\rxadsdotnet.cs(532,27): error CS0584: Internal Compiler Error: stage 'BIND' symbol
'RxAds.CommandLineInterface.BuildCommandList(object[], Autodesk.AutoCAD.DatabaseServices.ResultBuffer)'
c:\Projects\test\rxadsdotnet.cs(532,27): error CS0584: Internal Compiler Error: stage 'COMPILE' symbol
c:\Projects\test\rxadsdotnet.cs(353,17): error CS0584: Internal Compiler Error: stage 'COMPILE' symbol
'RxAds.CommandLineInterface'
c:\Projects\test\rxadsdotnet.cs(46,11): error CS0584: Internal Compiler Error: stage 'COMPILE' symbol 'RxAds'
c:\Projects\test\rxadsdotnet.cs(1,1): error CS0584: Internal Compiler Error: stage 'COMPILE' symbol ''
C:\Projects\test\RxAdsDotNet.cs: error CS0586: Internal Compiler Error: stage 'COMPILE'
error CS0587: Internal Compiler Error: stage 'COMPILE'
error CS0587: Internal Compiler Error: stage 'BEGIN'
Build complete -- 25 errors, 0 warnings
Building satellite assemblies...
---------------------- Done ----------------------
Build: 0 succeeded, 1 failed, 0 skipped
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
8 REPLIES 8
Message 2 of 9
Yeah, VS2002 has its problems. I ran into this and others so usually use new
C# compilers.
Try casting buf to IEnumerable explicitly. It will be slightly slower but it
will compile at least.
Albert
"Tony Tanzillo" wrote in message
news:4864174@discussion.autodesk.com...
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 3 of 9
Albert - Thanks, I'll try that.
"Albert Szilvasy" wrote in message news:4864160@discussion.autodesk.com...
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 4 of 9
This wouldn't be such a pain if ObjectARX didn't require 2002...without the
service pack no less...
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 5 of 9
My understanding is that VS2002 or 2003 is ok for
managed apps.
"Jon Rizzo" wrote in message news:4864226@discussion.autodesk.com...
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 6 of 9
Even for managed ObjectARX??
news:4864253@discussion.autodesk.com...
managed apps.
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 7 of 9
The requirement that you must use VS2002 when you use ObjectARX comes from 2
facts:
1. C++ name mangling rules are not standarized and they can change (in fact
they did change between VS2002 and VS2003)
2. The memory management contract in some ObjectARX API relies the caller
(you code) and the callee (AutoCAD) to share the same C/C++ runtime
(msvcr70.dll)
When you use the .NET API neither #1 nor #2 applies. If you build ObjectARX
applications with the /CLR C++ compiler flag then both #1 and #2 applies.
I'm not sure what you mean by managed ObjectARX. Can you clarify? (I know I
should be more familiar with our own marketing terms.)
Albert
news:4864438@discussion.autodesk.com...
managed apps.
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 8 of 9
What is 'managed ObjectARX' ?
"Jon Rizzo" wrote in message news:4864438@discussion.autodesk.com...
managed apps.
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
Message 9 of 9
I just meant calling managed C++ from an ObjectARX module...you answered my
question, thanks....
news:4864823@discussion.autodesk.com...
facts:
(msvcr70.dll)
Albert
managed apps.
C# compilers.
Albert
caused by this:
Object o = //
occurred.
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
Error: stage 'BIND'
stage 'COMPILE'
”Boost
