.NET
VS Not jumping to problem.
3 REPLIES 3
quigs
365 Views, 3 Replies
Good afternoon group,
Visual Studio has stopped jumping to the error if there is a problem
with my code.  For instance, if I left a Dialog open in AutoCad then if
I paused it would hit the same line every time, similar to this:
Dim myForm As New LoadMyDialog
ShowModalDialog(myForm)  (<-- THIS ONE)
Now it just does nothing.  It's very annoying, any ideas?
Ta,
Martin.
My name is Martin.. 😄
3 REPLIES 3
hgasty1001
in reply to: quigs
Try setting NEXTFIBERWORLD=0 in AutoCAD (need a restart of AutoCAD)
Gaston Nunez
quigs
in reply to: hgasty1001
That worked,
Thank you so much. :d
hgasty1001
Glad to help. I forgot to mention that setting fibers to 0 set AutoCAD in a diminished state, some things will not function properly  , this thread may help you to understand the situation: FIBERWORLD .
Gaston Nunez
”Boost
