• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • .NET
    Distinguished Contributor
    VS 2010
    755 Views, 8 Replies
    10-05-2010 03:04 PM
    Please don't tell me you can't run/use Visual Studio 2010 stuff inside AutoCAD 2011?.......
    Jerry Bryant
    "Swing hard and hope you hit it!"
    Please use plain text.
    *Expert Elite*
    Re: VS 2010
    10-05-2010 03:11 PM in reply to: jerry.bryant
    I have done a couple of small AutoCAD 2011 (AcadMap, actually) projects with VS2010, trageting .NET4.0. No issue so far.
    Of course I had to add this into acad.exe.config:
    <configuration>
      <startup useLegacyV2RuntimeActivationPolicy="true">
        <supportedRuntime version="v4.0"/>
      </startup>
    </configuration>
    Valued Mentor
    Re: VS 2010
    10-05-2010 03:13 PM in reply to: jerry.bryant
    You can't run Visual Studio 2010 stuff inside AutoCAD 2011, but you can use Visual Studio 2010 to develop apps for 2011, 2010,  2009,  and how ever far it goes back.
    You can also find your answers @ TheSwamp
    Valued Mentor
    Re: VS 2010
    10-05-2010 03:16 PM in reply to: Jeffrey_H
    Really no issues with 4.0 you must not be using any new features in 4.0 that directly interact with AutoCAD. Then I would play it safe with 3.5
    Re: VS 2010
    10-12-2010 09:35 AM in reply to: norman.yuan
    My acad.exe.config.....contains what you state below.
    However, I tried running a sample .DLL (sample taken from AutoCAD (2010) .Net Developers Guide), and I get the following errors:
    Command: netload
    Cannot load assembly. Error details: System.BadImageFormatException: Could not
    load file or assembly 'file:///D:\My Documents\Visual Studio
    2010\Projects\MyFirstProject\MyFirstProject\obj\Debug\MyFirstProject.dll' or
    one of its dependencies. This assembly is built by a runtime newer than the
    currently loaded runtime and cannot be loaded.
    File name: 'file:///D:\My Documents\Visual Studio
       at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase,
    Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark,
    Boolean throwOnFileNotFound, Boolean forIntrospection)
       at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase,
       at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef,
    Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
       at System.Reflection.Assembly.InternalLoadFrom(String assemblyFile, Evidence
    securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm,
    Boolean forIntrospection, StackCrawlMark& stackMark)
       at System.Reflection.Assembly.LoadFrom(String assemblyFile)
       at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
       at loadmgd()
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value
    [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure
    logging.
    To turn this feature off, remove the registry value
    [HKLM\Software\Microsoft\Fusion!EnableLog].
    Any ideas?
    attached is my acad.exe.config file (renamed so I could attach)
    Jerry Bryant
    *Expert Elite*
    Re: VS 2010
    10-12-2010 09:43 AM in reply to: jerry.bryant
    1. Do you use Acad2011?
    2. In your attached acad.exe.config, you have <!--....--> that comments out the needed setting. Are you sure you do not have <!--   ...  --> in your real acad.exe.config?
    Re: VS 2010
    10-12-2010 09:55 AM in reply to: norman.yuan
    Thx....that fixed the problem (I had the required line commented out...jeeez!)
    Jerry Bryant
    Valued Contributor
    mzakiralam
    Re: VS 2010
    11-14-2012 06:27 AM in reply to: jerry.bryant
    HI I have the same problem which is stated earlier. When I try to to load the .dll show following error:
    Command: netload
    load file or assembly 'file://\\home003.vih.infineon.com\alamzaki\My
    2010\Projects\MyFirstProject\MyFirstProject\bin\Debug\MyFirstProject.dll' or
    File name: 'file://\\home003.vih.infineon.com\alamzaki\My Documents\Visual
    Studio 2010\Projects\MyFirstProject\MyFirstProject\bin\Debug\MyFirstProject.dll'
       at loadmgd()
    logging.
    MY acad.exe.config file is:
    <configuration>
     <configSections>
    <section name="microsoft.web.services3" type="Microsoft.Web.Services3.Configuration.WebServicesConfiguration, Microsoft.Web.Services3, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/><section name="loggingConfiguration" type="Microsoft.Practices.EnterpriseLibrary.Logging.Configuration.LoggingSettings, Microsoft.Practices.EnterpriseLibrary.Logging, Version=2.9.9.2, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/></configSections><!--
      </startup>
     <!--All assemblies in AutoCAD are fully trusted so there's no point generating publisher evidence-->
     <runtime>
      <generatePublisherEvidence enabled="false"/>
     </runtime>
     <appSettings>
    <add key="WebServiceTimeout" value="1000000"/></appSettings><microsoft.web.services3>
    <messaging>
    <maxMessageLength value="51200"/><mtom clientMode="On"/></messaging><security>
    <timeToleranceInSeconds value="86400"/></security></microsoft.web.services3><loggingConfiguration name="Logging Application Block" tracingEnabled="true" defaultCategory="" logWarningsWhenNoCategoriesMatch="false"><listeners>
    <add fileName="rolling.log" rollSizeKB="0" timeStampPattern="yyyy-MM-dd" rollFileExistsBehavior="Increment" rollInterval="Day" formatter="Text Formatter" header="" footer="----------------------------------------" listenerDataType="Microsoft.Practices.EnterpriseLibrary.Logging.Configuration.RollingFlatFileTraceListenerData, Microsoft.Practices.EnterpriseLibrary.Logging, Version=2.9.9.2, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" traceOutputOptions="LogicalOperationStack" type="Microsoft.Practices.EnterpriseLibrary.Logging.TraceListeners.RollingFlatFileTraceListener, Microsoft.Practices.EnterpriseLibrary.Logging, Version=2.9.9.2, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" name="Rolling Flat File Trace Listener"/></listeners><formatters>
    <add template="{timestamp} ({win32ThreadId})  {message}
    Category: {category}{dictionary(
    {key}: {value})}" type="Microsoft.Practices.EnterpriseLibrary.Logging.Formatters.TextFormatter, Microsoft.Practices.EnterpriseLibrary.Logging, Version=2.9.9.2, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" name="Text Formatter"/></formatters><categorySources>
    <add switchValue="All" name="Information"><listeners>
    <add name="Rolling Flat File Trace Listener"/></listeners></add><add switchValue="All" name="Error"><listeners>
    <add name="Rolling Flat File Trace Listener"/></listeners></add><add switchValue="off" name="Trace"><listeners>
    <add name="Rolling Flat File Trace Listener"/></listeners></add></categorySources><specialSources>
    <allEvents name="All Events" switchValue="All"/><notProcessed name="Unprocessed Category" switchValue="All"/><errors name="Logging Errors &amp; Warnings" switchValue="All"/></specialSources></loggingConfiguration></configuration>
    I can not recity the problem. I am using VB2010 (Premium), AutoCAD2011. Windows 7 32 bit machine. Can you help me to solve this problem?
    Thanks in advance.
    Zakir
    ADN Support Specialist
    Balaji_Ram
    Re: VS 2010
    11-21-2012 09:32 AM in reply to: mzakiralam
    Hello Zakir,
    In what you have posted, I see those <!-- and -->
    You too seem to have the lines that specify the supportedRuntime in acad.exe.config commented.
    Can you try removing those comment markers ?
    Hope this helps.
    Balaji
    Developer Technical Services
    Autodesk Developer Network
