• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *Darcy
    VLA-object with no properties and methods
    80 Views, 4 Replies
    07-24-2005 01:58 PM
    I have compiled a class library that is exposed to com and I can
    (setq aa (vla-getinterfaceobject acadobj "ClassLibrary4.NET_Temp"))
    _$ (vlax-dump-object aa t)
    it returns:
    ; _NET_Temperature: nil
    ; No properties
    ; No methods
    T
    How do I setup the properties and methods to be able to use them from lisp?
    I am still trying to implement:
    http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dndotnet/html/callcomcomp.asp
    Any help would be greatly appreciated.
    Mathew
    Please use plain text.
    *Tony Tanzillo
    Re: VLA-object with no properties and methods
    07-24-2005 10:11 PM in reply to: *Darcy
    Did you check 'Register for COM Interop' in your
    project settings? If not, post your code if it is
    not ummmm proprietary.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
    http://www.acadxtabs.com
    "Darcy" wrote in message news:4909625@discussion.autodesk.com...
    it returns:
    ; No properties
    ; No methods
    T
    Mathew
    *Matthew
    07-25-2005 07:35 AM in reply to: *Darcy
    I have these attributes:
    < assemblykeyfileattribute="">
    < assemblytitle="">
    < clscompliant="">
    < comvisible="">
    and a Batch file:
    "C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Bin\sn.exe" -k
    PhysServer2.snk
    "C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Bin\tlbexp.exe"
    PhysServer2.dll /out:smileytongue:hysServer2.tlb
    "C:\WINdows\Microsoft.NET\Framework\v1.1.4322\regasm.exe"
    /tlb:smileytongue:hysServer2.tlb PhysSERVER2.dll
    2003\SDK\v1.1\Bin\gacutil.exe" /i PhysServer2c.dll
    Here is the class. I have checked the 'Register for COM Interop' checkbox.
    Public Interface iTemperature
    Property Celsius() As Double
    Property Fahrenheit() As Double
    Function GetCelsius() As Double
    Function GetFahrenheit() As Double
    End Interface
    Public Class NET_Temperature
    Implements iTemperature
    Private mdblCelsius As Double
    Private mdblFahrenheit As Double
    Public Property Celsius() As Double _
    Implements iTemperature.Celsius
    Get
    Celsius = mdblCelsius
    End Get
    Set(ByVal Value As Double)
    mdblCelsius = Value
    mdblFahrenheit = ((Value * 9) / 5) + 32
    End Set
    End Property
    Public Property Fahrenheit() As Double _
    Implements iTemperature.Fahrenheit
    Get
    Fahrenheit = mdblFahrenheit
    End Get
    mdblFahrenheit = Value
    mdblCelsius = ((Value - 32) * 5) / 9
    End Set
    End Property
    Public Function GetCelsius() As Double _
    Implements iTemperature.GetCelsius
    GetCelsius = mdblCelsius
    End Function
    Public Function GetFahrenheit() As Double _
    Implements iTemperature.GetFahrenheit
    GetFahrenheit = mdblFahrenheit
    End Function
    End Class
    Thanks again.
    Matthew
    "Tony Tanzillo" wrote in message
    news:4909714@discussion.autodesk.com...
    it returns:
    ; No properties
    ; No methods
    T
    Mathew
    *Tony Tanzillo
    07-25-2005 03:59 PM in reply to: *Darcy
    Search MSDN for the ClassInterfaceType and ProgID attributes.
    You're missing those, which is required for a class
    that is exposed via COM.
    "Matthew" wrote in message news:4910016@discussion.autodesk.com...
    < assemblytitle="">
    < clscompliant="">
    < comvisible="">
    and a Batch file:
    PhysServer2.snk
    End Interface
    Get
    End Get
    mdblCelsius = Value
    End Set
    End Property
    Get
    End Get
    End Set
    End Property
    End Function
    End Function
    End Class
    Thanks again.
    Matthew
    it returns:
    ; No properties
    ; No methods
    T
    Mathew
    *Matthew
    07-26-2005 05:08 PM in reply to: *Darcy
    Thanks Tony
    I posted to the Microsoft news group as well. Someone over there said that
    the Strong Name property page was in the Bata, and they took it out of the
    final release.
    Matthew
    news:4910636@discussion.autodesk.com...
    < assemblytitle="">
    < clscompliant="">
    < comvisible="">
    and a Batch file:
    PhysServer2.snk
    End Interface
    Get
    End Get
    mdblCelsius = Value
    End Set
    End Property
    Get
    End Get
    End Set
    End Property
    End Function
    End Function
    End Class
    Thanks again.
    Matthew
    it returns:
    ; No properties
    ; No methods
    T
    Mathew
