.NET
Valued Contributor
muthineni
Message 1 of 4 (268 Views)
VBA to VB.net
268 Views, 3 Replies
12-27-2011 08:09 PM
I have created a macro using VBA which is working fine and after that i have written the same logic in VB.net and that DLL is giving lot of errors. Is there any way that i can use the vba code as it is in VB.net? Thank you.
Jeff_M
Message 2 of 4 (266 Views)
Re: VBA to VB.net
12-27-2011 08:17 PM in reply to: muthineni
"As it is"? No. There are many differences between VBA & VB.NET. THey ARE similar, and you may be able to get your code to work with minimal effort. But you may get more help if you post the code you are trying to get to work, as well as posting what the errors are you are getting.
Moderator
Alexander.Rivilis
Message 3 of 4 (251 Views)
Re: VBA to VB.net
12-28-2011 01:23 AM in reply to: muthineni
Useful link: http://through-the-interface.typepad.com/through_the_interface/2010/05/more-translated-autocad-vba-t...
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Member
beeb.pm.Net
Message 4 of 4 (186 Views)
Re: VBA to VB.net
01-07-2012 10:08 PM in reply to: muthineni
To start with, get the thisdrawing equivalent using .net
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Private Shared ReadOnly Property ThisDrg() As AcadDocument
        Get
        Return Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
        End Get
    End Property
 Most of the VBA codes can be accessed though ThisDrg property
