.NET
.NET
*Terry W. Dotson
Message 1 of 3 (109 Views)
VBA to VB.NET - Receiving a drawing database as a parameter
109 Views, 2 Replies
03-15-2006 10:40 AM
I'm trying to use VBA to call a VB.NET sub, and pass a drawing database
as a parameter. I've included a string passed MyTestSub1 to verify that
the communication is there, and the alert dialog shows.
However when trying to pass a drawing database I get an error indicating
it "does not support expected interface".
Can "db As Autodesk.AutoCAD.DatabaseServices.Database" be used as an
incoming parameter?
Thanks in advance,
Terry
.NET Code
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Public Class MyTestClass
Public Sub MyTestSub1(ByVal mystr As String)
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(mystr)
End Sub
Public Sub MyTestSub2(ByVal db As
Autodesk.AutoCAD.DatabaseServices.Database)
db.RetainOriginalThumbnailBitmap = True
End Sub
End Class
VBA Code
Dim MyRef As Object
Set MyRef = Application.GetInterfaceObject("MyProject.MyTestClass")
MyRef.MyTestSub1 "Hello from VBA"
MyRef.MyTestSub2 ThisDrawing.Database
*Tony Tanzillo
Message 2 of 3 (109 Views)
Re: VBA to VB.NET - Receiving a drawing database as a parameter
03-15-2006 11:42 AM in reply to: *Terry W. Dotson
You are passing an AcadDatabase COM object, and
expecting to receive a Database managed wrapper
for AcDbDatabase. I don't think so.
If you're making an assumption like that, then I
would suggest making an investment in learning
a bit more about the .NET managed wrapper API,
before attempting any significant development
with it, beyond simple band-aids. Contrary to
what may have been implied by 'managed', the
possiblity of crashing AutoCAD is quite good even
with the safety net provided by managed code.
See the Database.FromAcadDatabase() method.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Terry W. Dotson" wrote in message news:5111860@discussion.autodesk.com...
incoming parameter?
Thanks in advance,
Terry
.NET Code
End Sub
End Sub
End Class
VBA Code
Dim MyRef As Object
*Terry W. Dotson
Message 3 of 3 (109 Views)
03-15-2006 12:23 PM in reply to: *Terry W. Dotson
That appears to be the solution. As usual your very helpful.
Thanks, Terry
Announcements
Need installation help?
