.NET
VBA to Dot-Net
2 REPLIES 2
451 Views, 2 Replies
VBA to Dot-Net
I'm new to programming AutoCAD with .net so maybe someone can help me with this lines of code written in VBA. I need to rewrite this functionallity in .net:
Public Sub showToolbar()
Dim menuGroup As AcadMenuGroup
Set menuGroup = ThisDrawing.Application.MenuGroups("acad")
Dim toolbar As AcadToolbar
' Check if Toolbar is already there
If (functions.CheckMenuEntry(menuGroup, TOOLBAR_NAME)) Then
Set toolbar = menuGroup.Toolbars.Item(TOOLBAR_NAME)
Else
Set toolbar = menuGroup.Toolbars.Add(TOOLBAR_NAME)
Dim measureDistance As AcadToolbarItem
Set measureDistance = toolbar.AddToolbarButton(toolbar.Count, "Distance between 2 Points", "Distance between 2 Points", "-VBARUN LaOsToolbar.measureDistance" + vbCr)
measureDistance.SetBitmaps "LaOs\measureDistance_small.bmp", "LaOs\measureDistance_large.bmp"
toolbar.Visible = True
If (toolbar.DockStatus acToolbarDockRight) Then
toolbar.Dock acToolbarDockRight
End Sub
Public Sub InsertMenu()
Dim menubar As AcadMenuBar
Set menubar = Application.menubar
' Check if Menubar is already there
If not (CheckMenuBarEntry(menubar, LTGBAU_NAME)) Then
Dim ltgBauMenu As AcadPopupMenu
Dim lispSubMenu As AcadPopupMenu
' Check if PopUpMenu is already there
If (CheckMenuEntry(Application.MenuGroups("acad"), LTGBAU_NAME)) Then
Set ltgBauMenu = Application.MenuGroups("acad").Menus.Item(LTGBAU_NAME)
Else
Set ltgBauMenu = Application.MenuGroups("acad").Menus.Add(LTGBAU_NAME)
Application.MenuGroups("acad").Menus.InsertMenuInMenuBar LTGBAU_NAME, menubar.Count
Dim ltgBauMenuItem As AcadPopupMenuItem
' Toolbar
Set ltgBauMenuItem = ltgBauMenu.AddMenuItem(ltgBauMenu.Count + 1, "Show Toolbar", "-VBARUN Menu.showLaOsToolbar" + vbCr)
' Separator
ltgBauMenu.AddSeparator ltgBauMenu.Count
' Lisp-Submenu
Set lispSubMenu = ltgBauMenu.AddSubMenu(ltgBauMenu.Count + 1, "Lisp-Functions")
Set ltgBauMenuItem = lispSubMenu.AddMenuItem(lispSubMenu.Count + 1, "Generate Böschungen", "bs" + vbCr)
End Sub
2 REPLIES 2
take a look at this http://discussion.autodesk.com/forums/thread.jspa?messageID=6199524飤
Patrick K Johnson
http:\\www.cadenhancement.com
I've watched this tutorial a few weeks ago and a few of my own .net applications are already working.
But with the code in my first post I have still some problems because I dont't know with classes I have to use. Maybe someone could help me with this
”Boost
