VB routine to VB.NET
gizmowiebe
gizmowiebe
I have a few years experience working with VB6 and VBA in combination with AutoCad. Now due to various reasons I would like to switch to VB.NET. For that I have downloaded Visual Basic 2008 Express.
Attached I added a VB routine that I would like to use in Visual Basic 2008 Express.
Does anybody know how to convert this
Thx in advance.
Wiebe
If you just want to get this into VB.NET pretty much as is then:
1) Create a new project.
2) Paste the code into a suitable place - a button click event in a windows app or Sub Main() of a console app.
3) Add references to the AutoCAD and AutoCAD/ObjectDBX type libraries.
4) Import the namespaces you'll be using (unless you want to fully qualify everything) - Autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common.
5) Declare your undeclared variables.
6) Fix your unterminated If blocks and For loop.
7) Enjoy.
Caution: Contents may be hot. Your mileage may vary. Results may not be typical.
No bytes were harmed during the production of this post.
gizmowiebe
Thx fantum for your prompt reply.
I got as far as the function attached. But everytime I get a HRESULT: 0x8007007E error on the blockreference parts.
Any ideas?
Regards
Wiebe
arcticad
Since you are Late Bound you don't have any type defined.
Use typename instead.
{code}
For Each entity In dbxDoc.ModelSpace
If TypeName(entity) = "IAcadBlockReference" Then
MsgBox(entity.name)
Next entity
{code}
(defun botsbuildbots() (botsbuildbots))
Is there a reason for using late binding?
