.NET
VB.net 2012 Error
18 REPLIES 18
Message 1 of 19
Amremad
1134 Views, 18 Replies
VB.net 2012 Error
hi all
this is my first program in vb.net and i'm so happy to do it
but i have a little problem
i made start action with start external program = c:\program files\AutoCAD 2010\acad.exe like picture
so when i VB.net i have this message
4.jpgso what can i do to solve this problem which to error when i run my dll using netload from autocad directly
18 REPLIES 18
Message 2 of 19
Amremad
in reply to: Amremad
any help
Message 3 of 19
Alexander.Rivilis
Instead of Debug->Start Debugging  try Debug->Attach to Process... and select acad.axe
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 19
Amremad
in reply to: Alexander.Rivilis
where can i fine "Instead of Debug"
Message 5 of 19
Amremad
i can't find "Attach to Process"
Message 6 of 19
Alexander.Rivilis
Attach to Running Processes with the Visual Studio Debugger:
Expert Elite Member
Message 7 of 19
Amremad
Message 8 of 19
norman.yuan
Do you happen to have Nero CD/DVD burning application installed? Anyway, if you searched the Internet for "debugger detected - please close it down and restart", you would have found tons of links. Some of them may help you:
http://www.indigorose.com/forums/threads/2357-Debugger-detected-Please-close-it-down-and-restart!
http://www.portraitprofessional.com/forum/showthread.php?tid=77
http://www.pcreview.co.uk/forums/debugger-bugging-me-t319053.html
http://forum.videohelp.com/threads/332379-Protection-error-Debugger-Detected
Norman Yuan
Drive CAD With Code
Message 9 of 19
Amremad
Smiley Happy
Message 10 of 19
Alexander.Rivilis
It was helped to you?
Expert Elite Member
Message 11 of 19
Amremad
i didn't try it yet , but i think this way doesn't help me , by i will try soon
Message 12 of 19
Amremad
doesn't work
any help plz
Message 13 of 19
Alfred.NESWADBA
if you are using VS2012 each new project is set to use Framework 4 (or 4.5). If you need to develop based on AutoCAD 2010 your project has to be set to Framework 3.5.
What Framework is set to your VS-project?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 14 of 19
Alexander.Rivilis
@Anonymous_world wrote:
doesn't work
What doesn't work? You can not attach to AutoCAD? You received any other error?
Expert Elite Member
Message 15 of 19
Amremad
sorry for late.
iam  already using .net framework 3.5 ,
and when i use attach to process , nothing happen , and my commmand desn't define . i need to fix the message when i run my program , i think attach to process not useful for me.
Message 16 of 19
Amremad
i tried my code in two computers
1- windows xp with cad2010
2- windows 7 with cad2010
and this message also apear
what can i do for this .
Message 17 of 19
Amremad
iam so sorry
Message 18 of 19
hgasty1001
Did you try the Norman suggestion about Nero products in the test machines? It seems it's the more probably cause of that message. I also found this: http://www.planetdvd.net/board/index.php/mv/tree/11011/0/
Gaston Nunez
Message 19 of 19
Hi, Gaston! amremad_world solved his problem. It was associated with the violation of the rules of this forum, for which he apologized.
Expert Elite Member
”Boost
