Dear All,
I can not figure out how to print my autocad drawings from a dedicated folder to pdf from a Visual Studio App.
So far, I can open a Autocad Drawing, upload the PC3 and PMP Files but can not figure out how to select a particular PaperSpace (called "A3 - ENGLISH").
Here below the code I have...I am pretty sure it can be simplify.
Imports System Imports System.IO Imports System.Text Imports Autodesk.AutoCAD.Interop Imports Autodesk.AutoCAD.Interop.Common Imports System.Data.SqlClient Imports System.Data.OleDb Imports Microsoft.Office.Interop Imports System.Runtime.InteropServices Imports Excel = Microsoft.Office.Interop.Excel Module Mdl_Print Dim AcadApp As AcadApplication Dim AcadDoc As AcadDocument Public Sub PDF_Print() Dim dirInfo As New DirectoryInfo(Frm_Main.LblFolder1.Text) Dim fileInfo As FileInfo Dim AcadApp As AcadApplication = New AcadApplication AcadApp.Visible = True AcadApp.WindowState = AcWindowState.acMax Dim success As Boolean = False For Each fileInfo In dirInfo.GetFiles("*.dwg") 'dwg for Autocad AcadDoc = AcadApp.Documents.Open(fileInfo.FullName) Dim oSS As AcadSelectionSet oSS = AcadApp.ActiveDocument.SelectionSets.Add("oSS") oSS.Clear() Try Dim ftype(0) As Int16 Dim fdata(0) As Object ftype(0) = 410 'layout fdata(0) = "A3 - ENGLISH" oSS.Select(AcSelect.acSelectionSetAll, , , ftype, fdata) Dim objPrefFiles As AcadPreferencesFiles Dim PC3PathOld As String Dim PC3PathNew As String Dim PMPPathOld As String Dim PMPPathNew As String Dim PtConfigs As AcadPlotConfigurations Dim PlotConfig As AcadPlotConfiguration Dim PtObj As AcadPlot Dim BackPlot As Object 'Set the preferences object objPrefFiles = AcadDoc.Application.Preferences.Files 'Get the current Printer Config Path (pc3) PC3PathOld = objPrefFiles.PrinterConfigPath MessageBox.Show(PC3PathOld, "old Printer Config path (pc3)") objPrefFiles.PrinterConfigPath = "C:\Users\ROBERT\Documents\Deb + Herve + Will\B - Herve\Technip\Autocad\1st project\OpenExcel\PC3 Files" PC3PathNew = objPrefFiles.PrinterConfigPath MessageBox.Show(PC3PathNew, "new Printer Config path (pc3)") 'Get the current Printer Desc Path (pmp) PMPPathOld = objPrefFiles.PrinterDescPath MessageBox.Show(PMPPathOld, "Printer Desc Path (pmp)") objPrefFiles.PrinterDescPath = "C:\Users\ROBERT\Documents\Deb + Herve + Will\B - Herve\Technip\Autocad\1st project\OpenExcel\PMP Files" PMPPathNew = objPrefFiles.PrinterDescPath MessageBox.Show(PMPPathNew, "Printer Desc Path (pmp)") PtObj = AcadDoc.Plot AcadApp.ActiveDocument.AcPlotType.acExtents() PtConfigs = AcadDoc.PlotConfigurations ''Add a new plot configuration PtConfigs.Add("PDF", False) ' ''The plot config you created become active PlotConfig = PtConfigs.Item("PDF") ''Use this method to set the scale PlotConfig.StandardScale = AcPlotScale.acScaleToFit ''Updates the plot PlotConfig.RefreshPlotDeviceInfo() 'Here you specify the pc3 file you want to use PlotConfig.ConfigName = "Herve.pc3" 'You can select the plot style table here PlotConfig.StyleSheet = "monochrome.ctb" 'You can select the Scale Line Weight PlotConfig.ScaleLineweights = True 'Specifies Paper Size PlotConfig.CanonicalMediaName = "ISO_A3_(420.00_x_297.00_MM)" 'Specifies whether or not to plot using the plot styles PlotConfig.PlotWithPlotStyles = True BackPlot = AcadDoc.GetVariable("BACKGROUNDPLOT") AcadDoc.SetVariable("BACKGROUNDPLOT", 0) 'Updates the plot PlotConfig.RefreshPlotDeviceInfo() MessageBox.Show("scale" & PlotConfig.StandardScale) MessageBox.Show("canonical media name" & PlotConfig.CanonicalMediaName) MessageBox.Show("config name" & PlotConfig.ConfigName) MessageBox.Show("plot type" & PlotConfig.PlotType) MessageBox.Show("scale line weight" & PlotConfig.ScaleLineweights) 'Now you can use the PlotTofile method If PtObj.PlotToFile(Replace(AcadDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then AcadDoc.Utility.Prompt(vbLf + "PDF Was Created") Else AcadDoc.Utility.Prompt(vbLf + "PDF Creation Unsuccessful") End If 'If you wish you can delete the plot configuration you created programmatically, and set the 'BACKGROUNDPLOT' system variable to its original status. PtConfigs.Item("PDF").Delete() PlotConfig = Nothing AcadDoc.SetVariable("BACKGROUNDPLOT", BackPlot) objPrefFiles.PrinterConfigPath = "C:\Users\ROBERT\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Plotters" objPrefFiles.PrinterDescPath = "C:\Users\ROBERT\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Plotters\PMP File oSS.Clear() If AcadDoc.Saved Then AcadDoc.Close(False) End If AcadDoc = Nothing AcadApp.Quit() AcadApp = Nothing success = True Catch ex As Exception MsgBox(ex.Message + vbLf + ex.StackTrace) success = False End Try ' AcadDoc.Close() AcadDoc = Nothing ' AcadApp.Quit() Next AcadApp.Quit() End Sub
Thank you
Herve
Are you looking to change a to a particular layout? If yes, go here - http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-5FA86EF3-DEFD-4256-BB1C-56DAC32BD868...
Well, basically, by default, my Autocad file opens on the layout "Model".
I have 3 other Layouts ("A3 - ENGLISH", "A3 - RUSSIAN" and "A3 - GERMAN").
What I am trying to do is to print only the layout "A3 - ENGLISH", for that, I create an AcadSelectionSet
First, I am trying to activate / select the layout "A3 - ENGLISH"
oSS.Clear()
AcadApp.ZoomExtents()
But it seems it doesnt do anything. The ZoomExtents() is performed in the layout "Model"
I might be wrong by using a AcadSelectionSet too...
PS: My application is a Windows Form, not an Autocad Wizard Template.
When I declare in VS the
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry
it returns an error.
ok, i'll think you need a few extra miles.
Which AutoCAD version?
Step 1: The Import errors. Did you add the AutoCAD xxx references: acdbmgd, acmgd, AcCoreMgd.dll?
And set the property COPY LOCAL=FALSE for those references.
Step 2: Add Import Plot Services
Imports Autodesk.AutoCAD.PlottingServices
Step 3 Start Activate Layout:
(I am not used to VB.NET so my VB suggestions might not always be correct):
Dim lm as LayoutManager= LayoutManager.Current
lm.CurrentLayout = "A3-Englisch"
Try these 3 steps and see if you get a way from the start line :).
I loaded the three dll but when I run the Marco (called from a button on the Main_Form) I get the follwing:
Could not load file or assembly 'Acdbmgd, Version=19.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format
I am with Autocad 2014
...and also, when I compile le project, I am getting the following warnings:
Warning 1 Possible problem detected while building assembly 'OpenExcel': Referenced assembly 'accoremgd.dll' targets a different processor OpenExcel
Warning 2 Possible problem detected while building assembly 'OpenExcel': Referenced assembly 'Acdbmgd.dll' targets a different processor OpenExcel
Warning 3 The referenced assembly "acmgd" could not be resolved because it has a dependency on "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which is not in the currently targeted framework ".NETFramework,Version=v4.0,Profile=Client". Please remove references to assemblies not in the targeted framework or consider retargeting your project. OpenExcel
This is how my Windows 7, 64bits, AutoCAD 2014, Visual Studio 2012 projects look like.
Notice the Copy Local =False for all three AC* references.
I would advise you to start with an empty VS project, without Excel, and then try to get a Plot To PDF sample running.
Then add the the necessary other functions.
I did the same but without success.
I read on a forum the acmgd.dll and acdbmgd.dll can only be use to made dll and can not be used in a stand-alone .EXE
Is that correct?
To be more detailled,
The Aplication I am doing is, a Windows Form under VS2010, that allows me to generate a document called 'Electrical Wiring Diagrams'.
Basically, on an excel spreadsheeet, I have information related to Electrical Consumers (tag, cable type, ID, size...).
The Application creates one Autocad Drawing per consumer and update the Block Attributes (text from the excel spreadsheet).
If the drawing already exist, the Application update the attributes only.
The Block is only made of text attributes only.
So far, I can generate the drawings, export the Attributes from Excel to the Autocad Drawings and vis-et-versa.
The remaining tasks I want to implement in my Application are:
Print the drawings in PDF.
Cloud all the Attributes that have changed between two revisions.
I am pretty sure the Print can be performed by the Interop so I will keep looking.
If I found, I will post the reply here.
Thanks you
Hello again,
So I solved the printing issue by using a solution proposed by Kean Walmsley (http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-basic.html); creating a dll.
Now, I have a other issue !
In the proposed code (in the dll) the PlotConfigurationName are declared as values (fixed) while, I would like these to be bound to my application...
To be more clear, in my VS Application, I have a form that let the user select the paper format (A0 to A4) and the Plot Style (acad.ctb, monochrome.ctb or Grayscale.ctb). So the question is how to link the choices made by the user to that dll ?
Thank you.
For info, here below the code for printing:
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.PlottingServices Imports System.Runtime.InteropServices Imports Autodesk.AutoCAD.Interop Namespace PlottingApplication Public Class PlottingCommands <CommandMethod("simplot")> _ Public Shared Sub SimplePlot() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim db As Database = doc.Database Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr LayoutManager.Current.CurrentLayout = "A3 - ENGLISH" ' We'll be plotting the current layout Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord) Dim lo As Layout = DirectCast(tr.GetObject(btr.LayoutId, OpenMode.ForRead), Layout) ' We need a PlotInfo object linked to the layout Dim pi As New PlotInfo() pi.Layout = btr.LayoutId ' We need a PlotSettings object based on the layout settings which we then customize ' Change the BACKGROUNDPLOT to 0 Dim bgPlot As Short = CShort(Application.GetSystemVariable("BACKGROUNDPLOT")) Application.SetSystemVariable("BACKGROUNDPLOT", 0) Dim ps As New PlotSettings(lo.ModelType) ps.CopyFrom(lo) ' The PlotSettingsValidator helps create a valid PlotSettings object Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current ' We'll plot the extents, centered and scaled to fit psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents) psv.SetUseStandardScale(ps, True) psv.SetStdScaleType(ps, StdScaleType.ScaleToFit) psv.SetPlotCentered(ps, True) ' We'll use the standard DWG to PDF.pc3 and ANSI A Paper size psv.SetPlotConfigurationName(ps, "DWG to PDF.pc3", "ANSI_A_(11.00_x_8.50_Inches)") ' We need to link the PlotInfo to the PlotSettings and then validate it pi.OverrideSettings = ps Dim piv As New PlotInfoValidator() piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled piv.Validate(pi) ' A PlotEngine does the actual plotting (can also create one for Preview) If PlotFactory.ProcessPlotState = ProcessPlotState.NotPlotting Then Dim pe As PlotEngine = PlotFactory.CreatePublishEngine() Using pe 'Create a Progress Dialog to provide info and allow the user to cancel Dim ppd As New PlotProgressDialog(False, 1, True) Using ppd ppd.PlotMsgString(PlotMessageIndex.DialogTitle) = "Custom Plot Progress" ppd.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = "Cancel Job" ppd.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = "Cancel Sheet" ppd.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = "Sheet Set Progress" ppd.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = "Sheet Progress" ppd.LowerPlotProgressRange = 0 ppd.UpperPlotProgressRange = 100 ppd.PlotProgressPos = 0 ' Let's start the plot, at last ppd.OnBeginPlot() ppd.IsVisible = True pe.BeginPlot(ppd, Nothing) ' We'll be plotting a single document ' Let's plot to file Dim toto As String toto = Mid(doc.Name, InStrRev(doc.Name, "\") + 1, 256) pe.BeginDocument(pi, doc.Name, Nothing, 1, True, "c:\plot\" & Mid(toto, 1, Len(toto) - 3) & "pdf") ' Which contains a single sheet ppd.OnBeginSheet() ppd.LowerSheetProgressRange = 0 ppd.UpperSheetProgressRange = 100 ppd.SheetProgressPos = 0 Dim ppi As New PlotPageInfo() pe.BeginPage(ppi, pi, True, Nothing) pe.BeginGenerateGraphics(Nothing) pe.EndGenerateGraphics(Nothing) '' Finish the sheet pe.EndPage(Nothing) ppd.SheetProgressPos = 100 ppd.OnEndSheet() '' Finish the document pe.EndDocument(Nothing) '' And finish the plot ppd.PlotProgressPos = 100 ppd.OnEndPlot() pe.EndPlot(Nothing) End Using End Using Else ed.WriteMessage(vbLf & "Another plot is in progress.") End If ' Change the BACKGROUNDPLOT to original value Application.SetSystemVariable("BACKGROUNDPLOT", bgPlot) End Using End Sub End Class End Namespace
You want to transfer parameters from you're Exe to AutoCAD?
C:\Program Files\...\acad.exe /nologo /p "AcadProfile" /PlotPaper="A1" /PlotStyle="acad.ctb"
[CommandMethod("CLA")] public void GetCommandLineArguments() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; ed.WriteMessage("\nGetCommandLineArguments"); foreach (string arg in Environment.GetCommandLineArgs()) ed.WriteMessage("\n{0}",arg); }
Command: CLA
C:\Program Files\Autodesk\Autodesk AutoCAD Map 3D 2014\acad.exe
/nologo
/p
AcadProfile
/PlotPaper=A1
/PlotStyle=acad.ctb
Command:
I am not sure to understand your code, where to place it and you to run it. In my VS.exe? in a new dll class ?
I understand is it not possible to load the acdbmgd, acmgd and AcCoreMgd.dll in a VS Windows Form, this is the reason I made the DLL for printing.
In my VS Windows Form, I have a Button that the result shall print all files in a folder to pdf format.
So far I manage to do the loop for each file to open them and print them but i do not now how to change the paper format and style in that dll since it is already declared in the dll.
I do not know if I am clear so I will try with a ewample;
In the DLL I have declare the paper format as "ANSI_A_(11.00_x_8.50_Inches)". So all prints will be in that format.
In my VS Windows Form, I have a form that let the user select the paper format but since it is declare in the DLL, it is not working at all.
Sorry for being such ignorant on the subject.
I'm not sure what you don't understand so let me try to explain it as simple as possible.
If i understood you correctly you have two programs:
1. Your "Forms" program as a standalone exe program collecting AutoCAD filenames and Excel data;
2. AutoCAD and a loaded DLL creating the PDF plot.
What you want is to tranfer values from your Forms.exe to your AutoCAD Plot program.
Start with youre AutoCAD program collecting values from it's commandline.
(Youre DLL should be automatically loaded using Autoload or loaded by AcadDoc.LSP, see sample below)
- Start a Windows Command Prompt(DOS CMD)
- Run AutoCAD:
C:\Program Files\...\acad.exe /nologo /p "AcadPlotProfile" /PlotPaper="A1" /PlotStyle="acad.ctb"
From: http://www.theswamp.org/index.php?topic=33538.0, thanks mohnston AcadDoc.lsp //must be somewhere in your AcadSearchPath folder (defun c:PdfPlot() (SETVAR "CMDECHO" 0) (command "netload" "C:/Program Files/AutoCAD 2010/PlotNET2010.dll" "PdfPlot") (SETVAR "CMDECHO" 1) (princ) )
[CommandMethod("PdfPlot")] public void PdfPlot() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; ed.WriteMessage("\nGetCommandLineArguments"); foreach (string arg in Environment.GetCommandLineArgs()) ed.WriteMessage("\n{0}",arg); string plotPaper=arg[xx]; string plotStyle=arg[xx]; SimplePlot( plotPaper, plotStyle, ...); }
This would start AutoCAD with you're variables.
Next you need Forms.exe to start AutoCAD with these parameters:
ProcessStartInfo acadPdfPlot = new ProcessStartInfo(); acadPdfPlot.FileName = @"C:\Program Files\...\acad.exe"; acadPdfPlot.Arguments = @"/nologo /p \"AcadProfile\" /PlotPaper=\"A1\" /PlotStyle=\"acad.ctb\""; Process.Start(acadPdfPlot);
I hope these steps may help you to get on track.
Note: this is just a simple example there other more advanded ways to do this.
