.NET
VB.NET: autocad tables and table breaks
2 REPLIES 2
jshimkus
1531 Views, 2 Replies
Through vb.net, I've added a brand new table to the drawing database.  I enable table breaking and set the break height to force the table to flow to the right.  I am now trying to determine how many additional 'tables' are being created while still in vb.net.  For example, I have a table with an initial height of 30".  If I set the setbreakheight = 10" and turn BreakEnabled = True.  How can I determine with vb.net that there are now 3 - 10" tables.
I've tried using the mytable.bounds and mytable.geometricextents to calculate the 'table' quantity, but that information does not always update once a transaction is complete and so far has been unreliable.
MEP 2012 with VB.NET
Thanks.
2 REPLIES 2
Balaji_Ram
in reply to: jshimkus
Hi John,
Have you tried using the "table.RecomputeTableBlock(True)" to update the geometric extents ?
Balaji
Developer Technical Services
Autodesk Developer Network
jshimkus
in reply to: Balaji_Ram
The .recomputetableblock(true) did the trick.  I can now determine how many 'tables' get added!!
”Boost
