whenever I try to save my curret drawing as I will get this error.
I was looking here what could be the issue but no success yet.
Do you now what could be the problem?
Many thanks.
I used standard method;
Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.Runtime <CommandMethod("SaveActiveDrawing")> _ Public Sub SaveActiveDrawing() Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim strDWGName As String = acDoc.Name Dim obj As Object = Application.GetSystemVariable("DWGTITLED") '' Check to see if the drawing has been named If System.Convert.ToInt16(obj) = 0 Then '' If the drawing is using a default name (Drawing1, Drawing2, etc) '' then provide a new name strDWGName = "c:\MyDrawing.dwg" End If '' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _ acDoc.Database.SecurityParameters) End Sub
Solved by jon-p. Go to Solution.
Sure, I am on my laptop and there is no issue to manipulate with any files 😕
Just try the same code, but this time saving to a folder, and see what happens. This may help:Disabling UAC
Gaston Nunez
sometimes if you do not lock the document then this type of error occurs. As you are using command method so document should be locked automatically. But you can try to lock the document in code explicitly and try the code once again.
Peter,
Yes, it happens. We fought with the SaveAs api in Autocad for a LONG time. The following is what we have thus far. It's a shame that something so basic / trivial has to be such a pain.
''' <summary> ''' saves the current drawing ''' </summary> ''' <param name="db">the database / drawing</param> ''' <remarks>We only had to write this because the autocad api is retarded</remarks> <Extension()> Public Sub SaveDamnYou(db As Database) Dim doc As Document = Nothing Try doc = DocumentManager.GetDocument(db) Catch 'db is in batch mode End Try 'If we have a document, attempt to call a quick save If doc IsNot Nothing Then If doc.IsReadOnly Then Throw New ROCException("Save failed. Drawing is Read-Only.") Else Try doc.Save() Catch ex As Exception doDBSave(db) End Try End If Else 'If no document, attempt to save the database itself doDBSave(db) End If End Sub ''' <summary> ''' Attempts to save the database to itself, or logs an error if it fails ''' </summary> ''' <param name="db"></param> ''' <remarks></remarks> Public Sub doDBSave(db As Database) Try Dim DwgFilePath As String = db.GetRealFilename db.SaveAs(DwgFilePath, True, DwgVersion.Current, db.SecurityParameters) Catch ex As Autodesk.AutoCAD.Runtime.Exception LogInfo("Acad Error Status: {0}".FMe(ex.ErrorStatus)) Throw End Try End Sub ''' <summary> ''' Saves the document via COM ''' </summary> ''' <param name="doc">document to be saved </param> ''' <remarks>Used by the above save routine to allow a lock document to be saved, because the API is SUPER retarded</remarks> <Extension()> Public Sub Save(doc As Document) Dim adoc As Interop.AcadDocument = CType(doc.AcadDocument, Interop.AcadDocument) 'adoc.Save() adoc.SendCommand("_QSAVE ") End Sub ''' <summary> ''' gets the real filename of the database. instead of .sv$ filenames ''' </summary> ''' <param name="db">the database / drawing</param> ''' <returns>returns the real filename</returns> ''' <remarks>http://through-the-interface.typepad.com/through_the_interface/2008/03/getting-the-ful.html</remarks> <Extension()> Public Function GetRealFilename(db As Database) As String Dim doc As Document = Nothing Try doc = DocumentManager.GetDocument(db) Catch 'This error indicates that there is no document object End Try 'is this open in batch mode? If doc Is Nothing Then Return db.Filename Else Return doc.Name End If End Function
@hgasty1001 wrote:Hi,
Gaston Nunez
No this did not help.
@mzakiralam wrote:Hi,
No success as well 😕 I tried to lock the document already.
jon-p: What references do I have to use? Some expressions are not recognized. I've got loaded AcCui, AcDbMgd, AcMgd.
Then;
Imports System
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Nothing else I do not need for code I have. But it seems that for your code I missed something.
The following are the references i have:
Imports System.Runtime.CompilerServices Imports System.Reflection Imports Autodesk.AutoCAD Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.ApplicationServices.Application Imports Autodesk.AutoCAD.DatabaseServices Imports System.Threading.Tasks Imports System.IO
Project References are:
AcCui, AcDbMgd, AcMgd, AcWindows, AdWindows, Autodesk.Autocad.Interop, and Autodesk.Autocad.interop.common
Granted, these are probably more than are required for the Save functionality, but i thought i'd include them just be safe... 🙂
If you're having issues with:
1. something called fme - change that to string.format()
2. Rocexception - change that to argumentexception
3. loginfo - change to console.writeline() or whatever your logging method is
if you have any other compile issues, post the messages and i can help you with them.
I have reference to accoremgd.dll (using A2014)
in addition to usual dll's
then this code should work:
<CommandMethod("SaveActiveDrawing",CommandFlags.Session)> _ Public Sub SaveActiveDrawing() Dim acDocMgr as DocumentCollection=Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager Dim acDoc As Document = acDocMgr.MdiActiveDocument Dim strDWGName As String = acDoc.Name 'Lock document Dim docLock As DocumentLock = acDoc.LockDocument Using docLock Dim obj As Object = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DWGTITLED") '' Check to see if the drawing has been named If System.Convert.ToInt16(obj) = 0 Then '' If the drawing is using a default name (Drawing1, Drawing2, etc) '' then provide a new name strDWGName = "c:\MyDrawing.dwg" End If '' save thumbnail preview acDoc.Database.UpdateThumbnail=15 '' Save the active drawing acDoc.Database.SaveAs(strDWGName, True, DwgVersion.Current, _ acDoc.Database.SecurityParameters) 'Close Database acDoc.Database.CloseInput(True) End Using 'Close Document try DocumentExtension.CloseAndDiscard(acDoc) Catch End try End Sub
Hmm no this does not work for me as well. Still the same error. I am running 2012 AutoCAD so I do not have AcCoreMgd.dll. That was present in 2013+ I think.
Is it really so difficult to SaveAs one drawing?
Peter,
Did my code not work for you? And, yes, in my experience, it really is that difficult to save a drawing... 😞
-Jon
@Jon-P: unfortunately not, or not yet,...I was trying to fix all the error in code that I had but some of them I was not able to fix. I am still learning to VBA but I was expecting that it will be easier to "just" save the drawing.
@Jon-P: Here is what issues I have with code you posted. References and imports are exactly what you wrote.
2/3 issues you wrote I have fixed, that one missing is FMe if I replace FMe by string.format() it does not help. Except this one there is a few more 🙂
Error 4 'Exception' is ambiguous, imported from the namespaces or types 'Autodesk.AutoCAD.Runtime, System'. C:\Users\xxx\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 52 33 SaveAsExample
Error 6 'FMe' is not a member of 'String'. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 76 35 SaveAsExample
Error 5 'GetRealFilename' is not a member of 'Autodesk.AutoCAD.DatabaseServices.Database'. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 72 45 SaveAsExample
Error 3 'Save' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 51 25 SaveAsExample
Error 2 Extension methods can be defined only in modules. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 34 10 SaveAsExample
Error 7 Extension methods can be defined only in modules. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 86 10 SaveAsExample
Error 9 Extension methods can be defined only in modules. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 101 10 SaveAsExample
Error 8 Type 'Interop.AcadDocument' is not defined. C:\Users\*\Documents\Visual Studio 2010\Projects\SaveAsExample\SaveAsExample\myCommands.vb 89 25 SaveAsExample
I really cannot believe that to save the drawing as is so complicated
Error4 can be solved if you defined the namespace before Exception. Modified code should be "System.Exception" or "Autodesk.AutoCAD.Runtime.Exception". This is occuring as System namespace and Autodesk.AutoCAD.Runtime both contains 'Exception'. So while compiler start to compile it gets cofused.
For other error , you should also post your whole code. Then people can help you easily. But from your error message it is evident that you are trying to use some method or properties from a class which is not belongs to that class. As an example, Error5: 'GetRealFilename' is not a member of 'Autodesk.AutoCAD.DatabaseServices.Database'. I suppose that you are trying to get the current drawing name. If so then you can get the drawing path from document class. from below code snippet you can get the active document name. Please share your code so that one can help you.
Dim doc as Document = Application.DocumentManager.MdiActiveDocument Dim fileName as string = Path.GetFileName(doc.Name)
thanks I fixex error 4
the code is here (was posted by Jon-P in this topic just bit updated when I tried to fix the errors)
Imports System Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports System.Runtime.CompilerServices Imports System.Reflection Imports Autodesk.AutoCAD Imports Autodesk.AutoCAD.ApplicationServices.Application Imports System.Threading.Tasks Imports System.IO ' This line is not mandatory, but improves loading performances <Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))> Namespace AutoCAD_VB_plug_in1 Public Class MyCommands ''' <summary> ''' saves the current drawing ''' </summary> ''' <param name="db">the database / drawing</param> ''' <remarks>We only had to write this because the autocad api is retarded</remarks> <Extension()> Public Sub SaveDamnYou(ByVal db As Database) Dim doc As Document = Nothing Try doc = DocumentManager.GetDocument(db) Catch 'db is in batch mode End Try 'If we have a document, attempt to call a quick save If doc IsNot Nothing Then If doc.IsReadOnly Then Throw New ArgumentException("Save failed. Drawing is Read-Only.") Else Try doc.Save() Catch ex As System.Exception doDBSave(db) End Try End If Else 'If no document, attempt to save the database itself doDBSave(db) End If End Sub ''' <summary> ''' Attempts to save the database to itself, or logs an error if it fails ''' </summary> ''' <param name="db"></param> ''' <remarks></remarks> Public Sub doDBSave(ByVal db As Database) Try Dim DwgFilePath As String = db.GetRealFilename db.SaveAs(DwgFilePath, True, DwgVersion.Current, db.SecurityParameters) Catch ex As Autodesk.AutoCAD.Runtime.Exception Console.WriteLine("Acad Error Status: {0}".FMe(ex.ErrorStatus)) Throw End Try End Sub ''' <summary> ''' Saves the document via COM ''' </summary> ''' <param name="doc">document to be saved </param> ''' <remarks>Used by the above save routine to allow a lock document to be saved, because the API is SUPER retarded</remarks> <Extension()> Public Sub Save(ByVal doc As Document) Dim adoc As Interop.AcadDocument = CType(doc.AcadDocument, Interop.AcadDocument) 'adoc.Save() adoc.SendCommand("_QSAVE ") End Sub ''' <summary> ''' gets the real filename of the database. instead of .sv$ filenames ''' </summary> ''' <param name="db">the database / drawing</param> ''' <returns>returns the real filename</returns> ''' <remarks>http://through-the-interface.typepad.com/through_the_interface/2008/03/getting-the-ful.html</remarks... <Extension()> Public Function GetRealFilename(ByVal db As Database) As String Dim doc As Document = Nothing Try doc = DocumentManager.GetDocument(db) Catch 'This error indicates that there is no document object End Try 'is this open in batch mode? If doc Is Nothing Then Return db.Filename Else Return doc.Name End If End Function End Class End Namespace
