.NET
VB.NET - Dynamic Blocks - Layers and Dimensions
4 REPLIES 4
patmang
846 Views, 4 Replies
Forgive me...I am a newbie, but studying hard!
I am writing this program that calls up a form and the user can input variables such as sizes, my code then calls in a dynamic block and I have it set so that the user may pick the insertion point. The block comes in ONLY IF THE BLOCK LAYERS ARE SET TO "0"! If I change the layers inside the block I get an "ebroken handle" error. "Yes the target dwg contains the layer if I do a clone wblock and insert."
Secondly, let's say my block has a "width" parameter and the user inputs what the desired width is--- my grips of the block stay where I have the parameter in the original block. If I move the block, it digitizes and shows original size of the block, but then restores to the user input size(s) when a command is complete.
What am I doing wrong?
I will post the code when I get home as I don't have it right know...I am currently using Jerry Winters latest book VB.Net for AutoCAD.
If anyone can be of some assistance or knows what I am talking about, please feel free to reply.
Thanks in Advance!
PATMANG
4 REPLIES 4
in reply to: patmang
I had the same problem. There are a number of errors in Jerry's code.
Try the attached version.
patmang@mangco.com wrote:
> Forgive me...I am a newbie, but studying hard! I am writing this program
> clone wblock and insert." Secondly, let's say my block has a "width"
> then restores to the user input size(s) when a command is complete. What
> am I doing wrong? I will post the code when I get home as I don't have
> for AutoCAD. If anyone can be of some assistance or knows what I am
> talking about, please feel free to reply. Thanks in Advance! PATMANG
patmang
Thanks for your help...I will try it...Are you telling me this is a fix that you have used already?
I can't wait to see how it works out!
Thanks again!
Yes. it's Jerry's code, but with the errors fixed.
> that you have used already? I can't wait to see how it works out! Thanks
> again!
patmang
Please send me an email address if you get a chance...
Any other areas I have to really watch out for or was it just in the blocks/clone chapters?
Layers worked like a charm, but my grips are staying in the original locations after the user changes the distance and when I go to move the block I see the original block back at it's original size. Aren't the grips in the block table record? Shouldn't they change with the new dimension(s)?
Anyway - I do APPRECIATE your HELP! so far - it seems you were on the same path as me!
Thanks Again!
I look forward to speaking with you over email - I don't want to overload the posting!
”Boost
