.NET
pderuiter77
Message 1 of 8 (260 Views)
VB.NET + COM GetEntity gives type mismatch
260 Views, 7 Replies
01-09-2013 04:30 AM
The following code keeps throwing a type mismatch on the GetEntity line
What am i doing wrong?
Dim obj As Object = Nothing
Try
    Dim pnt As Object = Nothing
    doc.Utility.GetEntity(obj, pnt, "test")
Catch ex As Exception
    Return False
End Try
The following code as well:
Dim obj as Object = Nothing
Try Dim pnt As Object = Nothing doc.Utility.GetEntity(obj) Catch ex As Exception Return False End Try
When i give no parameters i get an error that the number of parameters is not correct. That's fine, but that would imply
- that there is an overload accepting 1 parameter
- that the 'obj' parameter is of the wrong type
Moderator
Alexander.Rivilis
Message 2 of 8 (247 Views)
Re: VB.NET + COM GetEntity gives type mismatch
01-09-2013 05:13 AM in reply to: pderuiter77
Dim pnt(2) As Object
Try
    Return False
End Try
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
pderuiter77
Message 3 of 8 (241 Views)
01-09-2013 05:41 AM in reply to: Alexander.Rivilis
unfortunately no :smileyhappy:
I'm running a thread in another forum as well and it seems that autocad not being the top window at the time seems to have an effect on this issue
Moderator
Alexander.Rivilis
Message 4 of 8 (236 Views)
01-09-2013 05:56 AM in reply to: pderuiter77
Sorry. What about:
Dim pnt(2) As Double
pderuiter77
Message 5 of 8 (234 Views)
01-09-2013 06:01 AM in reply to: Alexander.Rivilis
yes i tried that, but it didn't work
and about bringing autocad to the front: wrong track. I built in a 500ms delay and the call rejected error disappears and the original error reappears
pderuiter77
Message 6 of 8 (217 Views)
01-09-2013 07:44 AM in reply to: pderuiter77
I gave up and used early binding instead. That worked
Valued Mentor
jeff
Message 7 of 8 (201 Views)
01-09-2013 02:10 PM in reply to: pderuiter77
Are these replies to feedback at another forum?
You can also find your answers @ TheSwamp
pderuiter77
Message 8 of 8 (189 Views)
01-09-2013 11:28 PM in reply to: pderuiter77
No,
i was referencing some findings in the other thread which at first glance seemed to have relevance.
i didn't want to cross post, but the gentleman in the other thread recommended this group so i posted here, but since he kept helping i didn't want to abandon that thread
You are not logged in.
Ask the Community
