Using observer paradigm to make my AutoCAD VB.NET program truly OOP
10:58 AM
Wondering if someone could show me how to implement an observer pattern for AutoCAD programming in VB.NET?
Currently I have a lot of working Autocad code in VB6 which the company wants me to migrate to VB.NET. Well, that would
normally be straightforward ... yes? Unfortunately, not so in our case.... recently, our company decided that I need
to modify it to implement the MVC (Model View Controller) paradigm to make it truly OOP.
Currently, my move was to start with a simple one, opening a form and then grabbing the name of the drawing and putting
it as the caption of the form... now, that is easy... I simply put in the form_load event the .getvariable("dwgname") and I am done....
The problem lies in trying to implement observer patterns ... in the observer pattern I cannot simply call .getvariable("dwgname")
from the form_load event instead, I need to use objects that would use an interface to register themselves as observers as
the form loads but not necessary having to be residing in the form_load event... in fact ... if there is somehow a way for me
to make such a thing happen before the code goes through the form_load event then that would more completely separate
the View layer from the controller layer which gets implemented through the use of observers and observer related patterns.
I did a search for MVC but got nothing returned but Im hoping that someone viewing this new thread might have come across it
and please give me a clue how it can be done... thank you so much for all the kind help you could give ... all suggestions welcome
Gratefully,
Matt
Gratefully,
Matt
