.NET
Contributor bej
bej
Message 1 of 3 (240 Views)
Using forms in C++/CLI AutoCad plugin
240 Views, 2 Replies
08-04-2013 11:41 PM
I'm having a problem displaying a custom windows form in my C++/CLI AutoCad 2014 plugin.
The code is posted below. The application does nothing AutoCad specific, it only opens a windows form I've created.
What happens when I call this command is that if I let the form display on screen for some time, AutoCad will crash, usually within 1-2 minutes after the form has opened.
Is there any known problems calling a Windows Form from a C++/CLI AutoCad plugin?
[CommandMethod("TestGUI")]
static void TestGUI()
MyForm ^myForm = gcnew TestProj::MyForm();
Autodesk::AutoCAD::ApplicationServices::Application::smileyfrustrated:howModelessDialog(myForm);
Bjørn Egil Jenssen
ADN Support Specialist
fenton.webb
Message 2 of 3 (218 Views)
Re: Using forms in C++/CLI AutoCad plugin
08-05-2013 02:44 PM in reply to: bej
can't see anything wrong with your code, so we need to see a small rebuildable sample applications which shows the same problem to be able to help
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Contributor bej
bej
Message 3 of 3 (206 Views)
08-06-2013 05:03 AM in reply to: fenton.webb
It seems the problem did not occur by opening the Windows Form I had created. However, AutoCAD crashes as mentioned in my original post when calling the standard Windows::Forms::smileysurprised:penFileDialog from within my custom form.
After I discovered this, I replaced the standard Windows::Forms::smileysurprised:penFileDialog with Autodesk::AutoCAD::Windows::smileysurprised:penFileDialog, and this seems to have solved the problem. I have not experienced any AutoCAD crashes after this change.
Bjørn
You are not logged in.
Ask the Community
