.NET
Using [Serializable] and others .Net features
8 REPLIES 8
Message 1 of 9
Acmx
394 Views, 8 Replies
Hello All !
I was interested in the question of serialization of arbitrary
data associated with AutoCAD objects such as document,
entities, layouts using .Net serialization mechanism.
As a result I wrote a small .Net library which implements
this way of serialization. Now it allows arbitrary properties
serialization using Microsoft [Serializable] attribute for
documents, objects, layers, layouts. Including serialization of
drawing entity references.
Also the library overlaps some others commonly used tasks.
The library assemblies are available at http://acmx.chat.ru
8 REPLIES 8
Message 2 of 9
in reply to: Acmx
Ok looks interesting are youi developing this for sale
If so how much for source??
wrote in message news:5053500@discussion.autodesk.com...
Hello All !
Message 3 of 9
Acmx
in reply to: Acmx
I'm developing this library for fun and for sale too. I'm going to add some more functionality.
Could you write me what kind of license do you ask about at acmx@chat.ru ?
Message 4 of 9
in reply to: Acmx
Hi. Sorry to say this, but...
Rules and guidelines that govern most serious software
development, preclude licensing third party code that
does not include source, unless if is from an established,
reputable business entity that has been in business for
some amount of time; and it provides some significant
functionality that could not be arrived at via programming,
without significant expense.
Another major problem with your code, is that it appears
to be an 'alternative' API/object model, where the main
purpose is to create a dependence on itself, that is for the
most part, illegitmate.
In other words, I and many others don't need your code to
persist data in AutoCAD drawings. The API's we have can
be used to do that, and of course, we can also take the
same approach, and make the code we write that does the
same thingreusable, and most importantly, we have and
own the source.
Allowing one's self to be at your mercy, and to become
dependent on you, who can vanish into thin air at any
time, just as quickly as you appeared, is nothing short
of foolish.
If your code or library did something significant, that
most reasonably competent programmers could not do
on their own with some programming, and you were
an established, reputable business that had an existing
customer base; or demonstrated that you were making
a major investment in becoming that, then and only
then, can one give serious consideration to licensing
anything from you.
However, in absense of those prerequisites, my advice
to you, would be to not waste too much of your time
developing something if you're doing that mainly for the
purpose of licensing it to others, without also providing
them with the source code, or at least, with the option
to purchase it for a fee.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:5053906@discussion.autodesk.com...
Message 5 of 9
Acmx
in reply to: Acmx
Hello. Thank you for your attention and recall to provide a customer
with source.
And an agreement under which a customer is provided with code and source
is called licensing.
As for code - there are no question because, as you mentioned, a code
without source has non-zero value only for the big program products.
As for source - the first question to a customer is what license agreement
do he want to buy source under. It affects to a price.
In general at this stage the library is written for fun. If anybody needs,
for instance, a reusable source of a separate persistency mechanism like there
is only, I'll be able to write it for him when I have a free day.
By the way publishing the Acmx library I do not prevent you from taking
the same approach and creating something .Net-like for AutoCAD in your own.
What about the 'alternative' object model, it coexists with the standard AutoCAD
.net and COM object models not substituting them as you can see from Acmx classes
documentation. Writing an application which, for instance, operates with a set
of AutoCAD objects coupled with a set of data domain objects in memory,
this approach is nearly obvious.
The Acmx library is not making something significant, it is, in my honest opinion,
a collection of some ideas I had about what can be useful in connection with .Net and AutoCAD.
Message 6 of 9
in reply to: Acmx
>> what license agreement do he want to buy source
That's fine. As long as they have the option.
Message 7 of 9
in reply to: Acmx
The degree of abstraction and the need to write to another
'alternative' API is not something I can sanction only for the
sake of automating persistence. There needs to be a more
compelling reason.
Writing to an alternative API means that no longer can code
be maintained or worked with by anyone having experience
and familiarity with nothing more than the Autodesk APIs and
the .NET framework.
If I needed to hire programmers, should I post a help-wanted
advertisement, seeking persons that are experienced with the
"Acmx library" ?????
How many respondents do you think there'll be ?
I've nothing against the idea of using proprietary, third-party
APIs, but they must offer very compelling reasons to justify a
dependence on them, and the risks that come with that.
Message 8 of 9
in reply to: Acmx
"Tony Tanzillo" wrote ...
> The degree of abstraction and the need to write to another 'alternative'
> API is not something I can sanction only for the sake of automating
> persistence. There needs to be a more compelling reason.
From an educational perspective, I think it's quite helpful. It's
interesting to see generics applied to a real-world situation.
Fred Chateau
fchateauAtComcastDotNet
Message 9 of 9
Acmx
in reply to: Acmx
Ok, more compelling reason is one more general tendency in software development - creating more unified helper API for existing ones simplifying the clients code particularly for some range of applications.
I agree that knowledge of original APIs is most valuable!
Alternative APIs often have some generalizations that help you
not to hire a lot of programmers to implement or maintain code.
E.g. it's easy to provide objects, layers, layouts, documents
with an interface like IHavingNamedProperties than write or
maintain different code for each case.
May be zero, I'm so busy last time
Yes, what about third-party code without sources, may be it risky at the beginning, but developing over raw original API is sometimes costly.
”Boost
