Hi, I'm trying to manage a list of strings at the application level.
The list is to be created/updated/deleted by a command passed on any open drawing. The list is transient, doesn't survive the closing of AutoCAD.
I must have only one copy of this list for all documents, NOT one list per document, as described in http://through-the-interface.typepad.com/through_the_interface/2006/10/perdocument_dat_2.html
Solved by norman.yuan. Go to Solution.
Maybe keyword static can help you?
Facebook | Twitter | LinkedIn
One of my blog articles might be a bit of help:
http://drive-cad-with-code.blogspot.com/2010/09/command-method-static-or-not-static.html
Norman Yuan
