.NET
Updating block attributes with vb.net
2 REPLIES 2
The_Caddie
3180 Views, 2 Replies
I would like to know how i could use VB.net to update block attributes.
About 2 years ago I wrote my first small program but have since come to a point I would like to refine and update it. The original was developed in AutoCADs own VBA but I was interested to know if I could achieve the same with VB.net instead?
Below is the original code from 2 years ago, remember the biggest hurdele for me is how to update the attributes in AutoCAD.
Option Explicit
Private Objexcel As Excel.Application
Private ObjWorkbook As Workbook
Private Sub Frame1_Click()
End Sub
Private Sub UserForm_Initialize()
Dim ObjRange As Range, ObjCell
Dim sFolder As String, sDefSheet As String
Dim iRow_counter As Integer
Dim sDwgFile As String
    iRow_counter = 0
    'Check of de ACAD-tekening reeds is opgeslagen..
    sFolder = fGetDefinitionSheetPath(AcadApplication.ActiveDocument.FullName)
    If sFolder <> "" Then
        'Bepaal de naam van het definitie-bestand bij de betreffende tekening..
        sDefSheet = Left$(AcadApplication.ActiveDocument.Name, _
                        InStrRev(AcadApplication.ActiveDocument.Name, ".")) & DEF_SHEET_EXT
        sDefSheet = sFolder & "\" & sDefSheet
        'Check op aanwezigheid van Excel-definitionsheet..
        If Not fExistsDefinitionSheet(sDefSheet) Then
            'Kopieer het standaard definitionsheet..
            Call fCopyDefinitionSheet(sDefSheet)
        'Openen van Excel...
        Set Objexcel = CreateObject("Excel.Application")
        Objexcel.Visible = False
        Set ObjWorkbook = Objexcel.Workbooks.Open(sDefSheet)
        'Selecteren van de in Excel gedefinieerde range met de naam "Artikelinhoud"...
        Set ObjRange = ObjWorkbook.Names("Artikelinhoud").RefersToRange
        For Each ObjCell In ObjRange
            'Vullen van ComboBox met: Inhoudarticle , stored_count
            ComboBox1.AddItem ObjCell.Value
            'In Column "2" het aantal elementen (stored_count) plaatsen:
            ComboBox1.Column(1, iRow_counter) = ObjWorkbook.Worksheets(3).Cells(ObjCell.Row, 3) + 1
            iRow_counter = iRow_counter + 1
        Next
        'Vullen van Algemene informatie...
        TextBox1 = ObjWorkbook.Worksheets(1).Cells(1, 1)
        TextBox2 = ObjWorkbook.Worksheets(1).Cells(2, 1)
        TextBox3 = ObjWorkbook.Worksheets(1).Cells(3, 1)
        '''TextBox4 = ObjWorkbook.Worksheets(1).Cells(4, 1)
        TextBox5 = ObjWorkbook.Worksheets(1).Cells(2, 2)
        TextBox7 = ObjWorkbook.Worksheets(1).Cells(2, 3)
        ObjWorkbook.Worksheets(3).Cells(31, 3).Value = "0"
        'ComboBox krijgt de eerste waarde uit de lijst...
        ComboBox1.ListIndex = 0
        'Opvragen van de tweede column "stored_count" uit de ComboBox1 als volgt:
        If ComboBox1.ListIndex >= 0 Then TextBox6 = ComboBox1.Column(1)
        'Set the focus to Textbox1 and highlight the text...
        UserForm1.TextBox1.SetFocus
        UserForm1.TextBox1.SelStart = 0
        UserForm1.TextBox1.SelLength = Len(UserForm1.TextBox1.Text)
    Else
        Call MsgBox("Sla eerst uw tekening op in de projectmap, daarna kunt u kaders toevoegen!", vbExclamation + vbOKOnly, Me.Caption)
        Unload UserForm1
        sDwgFile = ShowSave("Drawing Files (*.dwg)" + Chr$(0) + "*.dwg" + Chr$(0) + _
                "All Files (*.*)" + Chr$(0) + "*.*" + Chr$(0), _
                DEF_FOLDER_DRAWINGS, "Save DWG as file")
        If sDwgFile <> "" Then
            Call AcadApplication.ActiveDocument.SaveAs(sDwgFile)
End Sub
Private Sub UserForm_Terminate()
''''This command queues the launch of the 'Layout Wizard' dialog
'''     ThisDrawing.SendCommand ("(command ""_DATALINKUPDATE"")" & vbCr)
'''     ' This command queues the second part of the macro
'''     ThisDrawing.SendCommand ("(command ""U"" ""K"")" & vbCr)
    'Imitate as it already saved...
    ObjWorkbook.Saved = True
    'sluit excel en leeg het geheugen...
    ObjWorkbook.Close
    Objexcel.Quit
    Set ObjWorkbook = Nothing
    Set Objexcel = Nothing
End Sub
Private Sub ComboBox1_Change()
    'Als er iets geselecteerd wordt, dan... Initieel wordt dit event ook uitgevoerd!!
        Label8.Visible = True
End Sub
Private Sub CommandButton2_Click()
    Unload UserForm1
End Sub
Private Sub CommandButton3_Click()
' Akkoord wanneer het een nieuw kader betreft!..
Dim objBlock As AcadBlock
Dim objBlockRef As AcadBlockReference
Dim InsertionPnt As Variant
Dim Atts As Variant
Dim i As Integer
Dim ObjWorksheet As Worksheet
Dim intNewRow As Integer
Dim strNewCell As String
Dim ftw As String
    UserForm1.Hide
    Set ObjWorksheet = ObjWorkbook.Worksheets(1)
    ObjWorksheet.Cells(1, 1).Value = TextBox1.Text
    ObjWorksheet.Cells(2, 1).Value = TextBox2.Text
    ObjWorksheet.Cells(3, 1).Value = TextBox3.Text
    '''ObjWorksheet.Cells(4, 1).Value = TextBox4.Text
    ObjWorksheet.Cells(2, 2).Value = TextBox5.Text
    ObjWorksheet.Cells(2, 3).Value = TextBox7.Text
    Set ObjWorksheet = ObjWorkbook.Worksheets(2)
    ObjWorksheet.Cells(26, 1).Value = ComboBox1.Text
    Set ObjWorksheet = ObjWorkbook.Worksheets(4)
    Set ObjRange = ObjWorksheet.UsedRange
    intNewRow = ObjRange.SpecialCells(xlCellTypeLastCell).Row + 1
    strNewCell = "A" & intNewRow
    ObjWorksheet.UsedRange.Cells(intNewRow).Value = ComboBox1
    Objexcel.DisplayAlerts = False
    ObjWorkbook.Save
    Set ObjWorksheet = Nothing
    InsertionPnt = ThisDrawing.Utility.GetPoint(, "Selecteer het startpunt:")
    Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(InsertionPnt, "C:\ICT\AutoCAD_2010\Customisations\20090409\A-3V.dwg", 1, 1, 1, 0)
    'Sets template scale...
    ftw = ObjWorkbook.Worksheets(2).Cells(32, 3).Text
    objBlockRef.XScaleFactor = ftw
    objBlockRef.YScaleFactor = ftw
    objBlockRef.ZScaleFactor = ftw
    If objBlockRef.HasAttributes Then
        Atts = objBlockRef.GetAttributes
        For i = LBound(Atts) To UBound(Atts)
            Select Case (Atts(i).TagString)
            Case "ONDERDEEL" ''the name of your attribute
                Atts(i).TextString = ComboBox1.Text
            Case "BLADNUMMER"
                Atts(i).TextString = ObjWorkbook.Worksheets(2).Cells(54, 12)
            Case "WERKNUMMER"
                Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(1, 1)
            Case "TEKENAAR"
                Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 1)
            Case "DATUM"
                Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 2)
            Case "VERDIEPING"
                Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 3)
            Case "PROJECT"
                Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(3, 1)
            'Case "STATUS"
                'Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(4, 1)
            End Select
            objBlockRef.Update
        Next
    Unload UserForm1
End Sub
2 REPLIES 2
Jeffrey_H
in reply to: The_Caddie
You can also find your answers @ TheSwamp
ognyandim
in reply to: Jeffrey_H
Try to adopt these to your current situation. The first is for traversing and the next is for block attribs edit. I use them both.
”Boost
