• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    tomg
    Update Attribute prior to Insert
    108 Views, 3 Replies
    05-29-2012 12:06 PM
    I have a routine that will change attribute text when the block is in the dwg. My problem is that I would like to set the attribute text prior to insertion. Every example that I have found uses promptentityoptions which returns a result.ObjectId. as shown below.
    BlockReference br = (BlockReference)tr.GetObject(result.ObjectId, OpenMode.ForRead);
    AttributeCollection attCol = br.AttributeCollection;
    What do I use in place of result.ObjectId?
    Tom
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: Update Attribute prior to Insert
    05-29-2012 12:51 PM in reply to: tomg
    Shortly do something like this:
                              string atag=ed.Getstring("\nEnter a tag: ").StringResult;
                              string value=ed.Getstring("\nEnter a new attribute value: ").StringResult;
                              // Then after the block was inserted
                               //Get visible attributes from BlockReference object
                                Autodesk.AutoCAD.DatabaseServices.AttributeCollection attcoll = bref.AttributeCollection;
                                foreach (ObjectId id in attcoll)
                                    AttributeReference atref = (AttributeReference)tr.GetObject(id, OpenMode.ForRead);
                                   if (atref.Tag== atag.ToUpper())
                                  atref.TextString=value;
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Active Contributor
    tomg
    05-29-2012 01:37 PM in reply to: Hallex
    I have something like this:
    try
         BlockTable bt = (BlockTable)tr.GetObject(sourceDb.BlockTableId,
                                OpenMode.ForRead, false);
         foreach (ObjectId btrId in bt)
            BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead, false);
            BlockReference br = (BlockReference)tr.GetObject(--What--, OpenMode.ForRead, false);
    	etc.
     In the BlockReference statement, what is the --What-- object.
    Tom
    New Member
    05-29-2012 09:30 PM in reply to: tomg
    For Each attID As ObjectId In RefBTR
                    attEnt = tr.GetObject(attID, OpenMode.ForRead)
                    If TypeOf attEnt Is AttributeDefinition Then
                        Dim attDef As AttributeDefinition = attEnt
                        Dim attRef As AttributeReference = New AttributeReference()
                        attRef.SetAttributeFromBlock(attDef, br.BlockTransform)
                        If attRef.Tag = sTagName Then
                            attRef.TextString = sValue
                            Exit Sub
                Next
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                tr.Abort()
            Finally
                tr.Commit()
            End Try
