.NET
Update Attribute prior to Insert
3 REPLIES 3
tomg
362 Views, 3 Replies
I have a routine that will change attribute text when the block is in the dwg. My problem is that I would like to set the attribute text prior to insertion. Every example that I have found uses promptentityoptions which returns a result.ObjectId. as shown below.
BlockReference br = (BlockReference)tr.GetObject(result.ObjectId, OpenMode.ForRead);
AttributeCollection attCol = br.AttributeCollection;
What do I use in place of result.ObjectId?
Tom
3 REPLIES 3
Hallex
in reply to: tomg
Shortly do something like this:
                          string atag=ed.Getstring("\nEnter a tag: ").StringResult;
                          string value=ed.Getstring("\nEnter a new attribute value: ").StringResult;
                          // Then after the block was inserted
                           //Get visible attributes from BlockReference object
                            Autodesk.AutoCAD.DatabaseServices.AttributeCollection attcoll = bref.AttributeCollection;
                            foreach (ObjectId id in attcoll)
                                AttributeReference atref = (AttributeReference)tr.GetObject(id, OpenMode.ForRead);
                               if (atref.Tag== atag.ToUpper())
                              atref.TextString=value;
~'J'~
tomg
in reply to: Hallex
I have something like this:
try
     BlockTable bt = (BlockTable)tr.GetObject(sourceDb.BlockTableId,
                            OpenMode.ForRead, false);
     foreach (ObjectId btrId in bt)
        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead, false);
        BlockReference br = (BlockReference)tr.GetObject(--What--, OpenMode.ForRead, false);
	etc.
 In the BlockReference statement, what is the --What-- object.
Tom
in reply to: tomg
For Each attID As ObjectId In RefBTR
                attEnt = tr.GetObject(attID, OpenMode.ForRead)
                If TypeOf attEnt Is AttributeDefinition Then
                    Dim attDef As AttributeDefinition = attEnt
                    Dim attRef As AttributeReference = New AttributeReference()
                    attRef.SetAttributeFromBlock(attDef, br.BlockTransform)
                    If attRef.Tag = sTagName Then
                        attRef.TextString = sValue
                        Exit Sub
                    End If
                End If
            Next
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            tr.Abort()
        Finally
            tr.Commit()
        End Try
”Boost
