.NET
JamieVJohnson2
Message 1 of 4 (584 Views)
Unknown error when closing AutoCAD 2013
584 Views, 3 Replies
05-03-2012 04:49 PM
I get this common exception while debugging right after I close AutoCAD.  I have not even run any commands that belong to my project, just open AutoCAD and Close AutoCAD.  Anybody have any ideas that can tell me what to check into?
--------------------------- Exception in c:\program files\autodesk\applicationplugins\sbd.bundle\contents\aalsbin\acadaliasapp.arx ARX Command --------------------------- Unhandled Exception 1 (Access Violation Reading 0x89a63aa8) at address 775E32D0h --------------------------- OK   ---------------------------
--------------------------- Exception in c:\program files\autodesk\applicationplugins\sbd.bundle\contents\aalsbin\acadaliasapp.arx ARX Command --------------------------- Unhandled Exception 80000003 (80000003h) at address 776540BFh --------------------------- OK   ---------------------------
Call Stack:
  [In a sleep, wait, or join]  > mscorlib.dll!System.Threading.WaitHandle.WaitAny(System.Threading.WaitHandle[] waitHandles, int millisecondsTimeout, bool exitContext) + 0xb6 bytes    System.dll!System.Net.TimerThread.ThreadProc() + 0x2d6 bytes    mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool ignoreSyncCtx) + 0xdc bytes    mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) + 0x3b bytes    mscorlib.dll!System.Threading.ThreadHelper.ThreadStart() + 0x4d bytes    [Native to Managed Transition]
jvj
jvj
Valued Mentor
KerryBrown
Message 2 of 4 (577 Views)
Re: Unknown error when closing AutoCAD 2013
05-03-2012 06:08 PM in reply to: JamieVJohnson2
Isolate acadaliasapp.arx
test
report it to the developer if necessary.
class keyThumper<T> : Lazy<T>;      another  Swamper
JamieVJohnson2
Message 3 of 4 (325 Views)
02-28-2013 09:44 AM in reply to: JamieVJohnson2
I still have not gotten to the bottom of this.  I wouldn't know the first thing about isolating an app pluggin that is autoloaded with the core of AutoCAD.  Now that I have some time to investigate, I would like to solve it.
jvj
jvj
Moderator
Alexander.Rivilis
Message 4 of 4 (313 Views)
02-28-2013 01:38 PM in reply to: JamieVJohnson2
jvj
In order to isolate this application just rename (or move in other location) file:
That should be enough.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
You are not logged in.
Ask the Community
