.NET
.NET
Distinguished Contributor
wesbird
Message 1 of 2 (402 Views)
Unhandled Exception C0000005(Access Violation Reading 0x0000) at address 886CEB5
402 Views, 1 Replies
12-06-2005 11:22 AM
When I finish my .net application debug in AutoCAD, I got this error message:
Exception in acmgd.dll ARX Command
Unhandled Exception C0000005(Access Violation Reading 0x0000) at address 886CEB5h
What's reason it could be?
Thank you,
Merry Christmas
Wes
Khalique
Message 2 of 2 (402 Views)
Re: Unhandled Exception C0000005(Access Violation Reading 0x0000) at address 886CEB5
12-08-2005 06:45 AM in reply to: wesbird
Most likely it is because you declared a variable and used it without instantiating it.
When C# encounters an exception, it stops at the line where exception occurred. Add a try/catch block and examine the Exception object's message property. It will tell you more about the error.
try
Command that caused error
catch(Exception ex)
Debug.WriteLine(ex.Message);
Add the following using statement if not already added.
using System.Diagnotics;
kr
