.NET
.NET
Active Member
sandeep_vaal
Message 1 of 3 (370 Views)
Unable to read the attached DXF using Database.DXFIn()
370 Views, 2 Replies
06-24-2013 04:11 AM
I am new to the RealDWG. I am trying to read the dxf file using RealDWG. Most of the files do come in correctly. But there are some files where DXFIn() api just hangs. It does not throw any error or comes out of the API call, but simply hangs.
If I Open and then Save the attached file in latest AutoCAD(AutoCAD 14) in dxf format only then DXFIn function executes properly.
It looks like the version compatibility issue of dxf files. But what I am interested in is that how should I figure out which files needs to be resaved before my application hangs.
Here is the code I am using.
this.database = new Database(false/*build empty object*/, true/*assiciate this database to current document*/);
public void ReadFile(string fileName)
string fileExt = Path.GetExtension(fileName);
if(fileExt.Equals(".dxf", StringComparison.InvariantCultureIgnoreCase))
this.database.DxfIn(fileName, this.logFilePath);
else
this.database.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndReadShare, false /*allowCPConversion*/, string.Empty/*password*/);
Sandeep
ADN Support Specialist
fenton.webb
Message 2 of 3 (351 Views)
Re: Unable to read the attached DXF using Database.DXFIn()
06-24-2013 10:05 AM in reply to: sandeep_vaal
The fact that the DXF file loads fine in AutoCAD suggests to me that you have a problem in your RealDWG application implementation. Have you used this template as the basis for your RealDWG app? http://adndevblog.typepad.com/autocad/2012/05/fentons-recommended-hostapplicationservices-implementa...
Another point... As with any code that processes many data files; I recommend that your RealDWG app is hosted in a separate exe that your processor app exe, this is so your processor app can monitor the health of your separate RealDWG exe app in case of failure, so that your program stays up.
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Active Member
sandeep_vaal
Message 3 of 3 (326 Views)
06-24-2013 10:44 PM in reply to: fenton.webb
Thanks for the reply. The template solved my problem
Thanks again for the reply.
